I always use it, because it's only a couple bucks more a tank, and i only want the best for my car, i just don't want to be doing damage to it. Is it ok?
Is it bad to run 92 octaine all the time?
Yep it is perfectly fine for your car2002 M5 Bright Metallic Silver <br />*Fully loaded and modded<br /><br />2005 GSXR 750<br />*Micron Serpent Race Exhaust *K&N Filter *Power Commander *Trying to hit 200 MPH!<br /><br />1970 SS 454 Chevelle Cortez Silver<br />*It can pass anything but a gas station
I use it too. It's probably not needed, but it seems to go further. When you get into mods with the potential to cause more than mild detonation you might want to consider it.<b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
If you use nitrous make sure you use 93 octane or boom i didnt run 93 once while i was spraying and had some pretty nasty detenations going on<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
Your just wasting your money unless you have your car modded or are running Nitrous, supercharger, turbocharger, etc. The higher octane reduces detonation in those instances but if your car is basically stock then regular 87 octane is fine and is what is recommended for our cars, the higher octane won't hurt the car but it is just wasting some extra cash, its your choice though. I usually run 89 octane because I have some mods and it appears that my car tends to run better with it. Each car is a different but its your choice and you know your car better. I'm just letting you know that it won't hurt it but if the car is basically stock its just wasting the extra cash that you could be saving for other things. Hope this helps.1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
Run a search, this was talked about not to long ago. Skull is right though, it is a waste of money.-Jason<br />Black 1993 Pontiac Firebird -Retired<br />Black 2002 Pontiac Trans Am -Sold-<br />Green 1996 Corvette Convertible -Sold-<p>In the market for \'67-\'73 Firebird!
