Question - FirebirdV6.com/CamaroV6.com Message Board
Question
  • Question
    I don't know if this belongs here since it sort of has part of 2 sections in it. Before I had my 3" pipe put in from the y-pipe all the way back I could punch it in first gear and spin the tires but now after I have had it done for a while when i punch it now it doesn't do that anymore. It will chirp between gear changes so I did't lose anything there. So If i put in the rear with 3.42's(or 3.73) I should be able to get that low-end power back right? My 1/4 times have improved with the 3" but with the gears I know it will help more. I am not completly done with my exhaust system yet since I want to get headers should I maybe have the pipe restricted back to 2.5" through the s-pipe? Thanks for any help.
    JR
    1996 Camaro 3.8<br />Edelbrock Exhaust, SLP Intake, Bosch, Platinum +4 Plugs, Accel Wires, SLP fan switch<p>\"Let the good times roll\"
    anyone w/ any insite?
    ttt
    JR
      It depends, do you plan on getting engine work done or using forced induction? If you plan on doing any of these things then you'll want to have the 3 inches and headers. If you plan on just keeping basic bolt-ons then you'll probably want to go to a smaller diameter.
      1 of a kind<p>Red 97 Camaro<p>Modifications: <br />SLP CAI, RK Sport Headers, Car Sound High Flow Cat, 3\" piping<br />3\" Steel driveshaft, SFC\'s, Panhard Rod, MAC Torque Arm<br />Manual Fan Switch<p>Best E/T:<p>60\' 2.152<br />330 6.271<br />1/8th 9.704<br />MPH 71.93
        To answer your question -
        Yes, going with a lower gear ratio will bring some torque down low and you'll get that back.
        2002 Camaro SS 6 Spd<br />Sebring Silver Metallic<br />Still breaking it in<p>Traded in - 2002 V6 5 Spd Camaro.<p>\"I\'ll never trust squirrels again.\"
          Thanks guys. I am doing a complete re-build of my engine w/ the H/C. So i'll let it alone then. thanks again
          JR
