So my Camaro is running better but at WOT I get a blinking SES light, only at WOT and it goes back off and when I pull the codes its PO300 random misfire. The cars running great at WOT ,so I have no clue anymore. Replaced every sensor on it except for the crank sensor. Vac. lines look good. Air/fuel is at 12.5ish at WOT have a cam so run it alittle rich. Any other suggestions before I take it into a dealer.
Blinking ses light only at WOT
Originally posted by Camaro3800v6Last edited by ssms5411; 07-25-2018, 06:33 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
How much boost are you running?
Originally posted by LETZRIDE View PostHow much boost are you running?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Took it out today with the transmissions tables fixed with hptuners, still get the damm blinking light. Im going to scan it next time and see if ai can pick up anything in the scans with hptuners. New tune with the transmissions tables fixed have it running awesome. I like it , thanks to Mike, Letzride.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Glad the changes made a big difference Steve- with regards to the misfires, just make sure you aren’t chasing ghosts and as silly as it sounds, insure none of your wires are burnt, nothing is broken at the connection terminals, coils are good, and none of yourr plugs are broken. The one plug in the passenger side is a pain and I have cracked the porcelain in the past installing it- and that can cause misfires.
See if you can get us a scan of what’s going on- this is certainly an odd issue to have.
Originally posted by LETZRIDE View PostGlad the changes made a big difference Steve- with regards to the misfires, just make sure you aren’t chasing ghosts and as silly as it sounds, insure none of your wires are burnt, nothing is broken at the connection terminals, coils are good, and none of yourr plugs are broken. The one plug in the passenger side is a pain and I have cracked the porcelain in the past installing it- and that can cause misfires.
See if you can get us a scan of what’s going on- this is certainly an odd issue to have.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Took the Camaro out, finally got a po306 code along with the po300 random misfire code , now I know where to start waiting for it to cool down, I read it with hptuners and not the aeroforce gauge. I think the hptuners picks up more when scanning. Will let you know what I find.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Heres a pic of number 6 plug wire. I think i need new heat sleeves. Mine look pretty old.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Ill find out tomorrow if that was the problem.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
A while back I had a blinking SES light when accelerating and I believe my serpentine belt was worn. found this also https://www.civicforums.com/forums/1...ire-p0300.htmlLast edited by Camaro3800v6; 08-02-2018, 06:19 AM.
Originally posted by Camaro3800v6 View PostA while back I had a blinking SES light when accelerating and I believe my serpentine belt was worn. found this also https://www.civicforums.com/forums/1...ire-p0300.html08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Its fixed, thanks for your guys help, it was the damm plug wire on #6 heat sleeves are pretty worn, ordered some 2500 degree heat sleeves. Now to move on to something else, got my reverse lights to look at and the oil filter housing and double roller to do.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
That’ll do it! Sometimes the answers are going back to basics and looking at the simple things we tend to over look because we believe it to be more complicated.
Glad you figured out the issue Steve
Originally posted by LETZRIDE View PostThat’ll do it! Sometimes the answers are going back to basics and looking at the simple things we tend to over look because we believe it to be more complicated.
Glad you figured out the issue Steve08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
- 1 like
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
