cool, let us know how she runs
Going with different cam
Are you getting it tuned right after?
I’ll have my Hptuners with me so in case I need to tune it. Should be pretty close ,206/216 115 LS and the new 212/212 113 LS but if it’s bad I’ll make some adjustments.Last edited by ssms5411; 11-07-2019, 02:37 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Got it dropped off , he noticed the fuel smell and looked under the hood right away and found injector 4 cracked. Ordered new Ev1 60lb injectors.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
- 1 like
Now just waiting on fuel injectors to get here Wednesday to fire it up. Then he’ll do the rear abs sensor and reverse lights. Maybe Friday or Saturday to pick it up.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
did you have them do any other oiling mods beside the cover ? I've been reading some posts on 3800 pro and Chicago garage about cleaning up casting flaws and porting the inlet/outlet in both the block and the timing cover, I think when I finally do get around to pulling my motor, im gonna try to get the oil flowing as good as I can with some porting , drilling mains , removing the balance shaft and plugging the hole for starters...
Did the oil volume mod, should raise the oil psi, 30-40 psi, yeah if your pulling the motor I could see doing some oil mods.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Looks great. Are you gonna do any other dress mods up on the motor ? I was thinking about hitting my valve covers with a soft brass wire brush and then some high gloss clear coat to give them that bright- brushed aluminum look.
