Thanks , No painting them is all I’m doing, the turbo will be enough show.lol Your idea sounds cool.
Going with different cam
Got it running, used the old injectors, wasn’t cracked just bad O-rings which was good since UPS lost my injectors. I have a video of it running but don’t know how to post it.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Rockauto sent me the wrong part again, the rear abs sensor was the wrong one, and it’s been too long to send it back. I guess you have to make sure they send you a part right away or your screwed. There goes another 30 bucks.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostRockauto sent me the wrong part again, the rear abs sensor was the wrong one, and it’s been too long to send it back. I guess you have to make sure they send you a part right away or your screwed. There goes another 30 bucks.
On one hand I get it. On the other hand, I ordered something and it never showed up. (or in your case, was wrong.) That's not cool.
Originally posted by ssms5411 View PostGot it running, used the old injectors, wasn’t cracked just bad O-rings which was good since UPS lost my injectors. I have a video of it running but don’t know how to post it.
Let us know how the tuning goes!
Yeah hopefully get it tomorrow, he said he blipped the throttle alittle and A/F was at 15.9 yikes.lol but it cruises in the 14 range so that’s good. Just needs some more fuel.Last edited by ssms5411; 11-14-2019, 07:06 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Got the new rear abs sensor in, and got the reverse lights working, had to run another power wire,but got them working.Picking it up tomorrow.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Thanks, no maybe I’ll give it a try but it’s been about a year so I doubt it.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Ya that is a little long - but you never know.
Yeah , I try to stock up on parts, but it’s not paying off.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Got it home, first start up you notice the balance shaft not spinning but It’s fine cruising, no KR so that’s good, oil pressure is 50-60 psi when cruising around and around 30 psi at idle hot. I guess it’s normal but don’t see where the oil volume mod is worth it. Need to work on the tune will do it this weekend. Just gave it a quick tune with lots of fuel. Oh and the abs light came on again now showing front left sensor instead of rear. Damm abs.lol08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Well that’s good then, thanks for the info.I was going by the reviews on ZZPerformance,some said it raised their oil pressure.Last edited by ssms5411; 11-15-2019, 09:17 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
What do you mean you can see the balance shaft not turning? Where are you looking?
