Originally posted by LETZRIDE
View Post
Found a coolant leak
Originally posted by ssms5411 View PostYeah , I try to do most work but can’t do much anymore because of a bad back and had a stroke.
Last edited by ssms5411; 12-06-2019, 08:41 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Started it up today with the TB coolant bypass, let it get to 140 degrees temp and the oil looks good. Could the coolant mix with the oil through the TB? Going to let it get to full temp. tomorrow and see if it’s leaking any where.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
There's a crankcase vent in the tb coming through the manifold, from the driver side head. I suppose if the tb gasket was bad, some coolant couldve gotten into the oil via that vent passage as that vent is generally lower pressure than the pcv side.
Originally posted by mdiesel View PostThere's a crankcase vent in the tb coming through the manifold, from the driver side head. I suppose if the tb gasket was bad, some coolant couldve gotten into the oil via that vent passage as that vent is generally lower pressure than the pcv side.Last edited by ssms5411; 12-09-2019, 06:40 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Was thinking about having my coolant system pressure tested if I don’t find the leak, just to be safe.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Started it up today let it get to 180 temp, no leaks, oil looks good, so far it’s good, if it was the lower intake I would assume it would of leaked by now. So I’m letting it cool down so I can add coolant from where I did the TB. Will drive it tomorrow and make sure.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
- 1 like
Took it out today and beat on it, no leaks, thankfully. Will change the cheap oil out and filter with Amsoil in a couple of weeks.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by Namrepus28 View PostAwesome! Glad to hear that you solved the problem!
