Manual Fan Switch - FirebirdV6.com/CamaroV6.com Message Board
Manual Fan Switch
  • Manual Fan Switch
    Does anyone have a manual fan switch
    or know how to install it? Think its possible for a guy with no experience in car electronics could do it?
    \'02 W68 Pewter Metallic Firebird-RKSport Headers, Catco 3\" cat, SLP Loudmouth, Fast Toys ram air, K&N, !Air Silencer, shaved airbox lid, SLP fan switch, BMR strut tower brace
    It is incredibly easy. I just did it the other day on my car. The hardest part is figuring out where you want to mount the switch. All you need to do is tap into 4 wires and mount the switch. I found a generic one on E-bay for $35 that comes with LED's (which you dont have to use) or you can buy one from SLP I believe. Go for it.
    98 Silver Camaro V6<br />15.238 @91.74 w/ 2.288 60\'<br />Mods: K&N, FTRA, Pacesetter Headers, Spec 3 Clutch, 160 Thermo, TSP Rumbler, 3\" Catco, Whisper Lid, 3.42\'s w/LSD, Aluminum DS, Man Fan Switch<br /><br /> <a href=\"http://www.cardomain
      I built mine using a switch and speaker wire and soldered the wire to the switch. It cost me $11.82 from Radiosnack.
      2002 5-spd NBM Camaro
      Details: www.1lev6.com
        its really easy. is suggest using the slp one cause its really easy and has instruction too. go for, not hard at all.
        2000 3.8 A4 Pewter Camaro
          hey nate was that one easy to install did it come with directions im thinkin about gettin it this weekend
          1995 Camaro 3.4 M5 - Project<br />1998 Camaro 3.8 A4 - Daily<br />Aim:V6OnSpeed<br /> <a href=\"http://www.cardomain.com/memberpage/576233/1\" target=\"_blank\">http://www.cardomain.com/memberpage/576233/1</a>
            It's all about 'H' and 'J' on the underhood wiring harness, passenger side. Grounding one of those wires will cause the low fans to come on, the other will cause the high fans to come on.
            I have a switch that has low, off, high. Low illuminates one LED, high illuminates two LEDs.
            \'97 Camaro: GN Turbo w/intercooler, 3.42s w/ Auburn HD posi, Bulletproof 4L60E-HD, stage II shift kit, Vette servo, MSD Ign, K&N, Ported TB/MAF, 3\" FlowMaster, 160* thermo, HPTuners v1.6
              this is a little off topic but im going to ask anyways. if you install the switch to turn on your fans, do they still come on automatially or are you totally responsible for turning them on?
              1987 Buick Grand National drivetrain in my 1993 Pontiac Firebird. PT53 turbo, 212/212 comp cam, 3400 lockup converter, stock heads, Precision bar & plate FMIC with 3\" piping, 1994 z28 rearend, hotwired walbro 255 fuel pump, Nitto drag radials
                most switches i've seen have three settings:
                high: fans on high
                low: fans on low
                stock: the fans return to their stock settings, so they'll turn on when they're supposed to on their own.
                1996 Pontiac <a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">Firebird</a> <br />Black, 3.8L A4
                  6 days ago
