So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery connections. Got dark so will mess with it tomorrow. Tried both keys so maybe not VATS. Thinking BCM . Will double check grounds and what not, Not hearing anything from the starter, It’s about a year old. Any other suggestions?
No start problem
Thinking about it, could be the starter power wire. Did that few years back I think so will check that also.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Everything looks good, going to jack it up this next week and take a look at the starter wire and test the starter.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Found my extra starter finally, of course it had to be in the back of my storage shed, it fell behind the tubs. lol About 10 tubs in spent the day searching the office, downstairs room and beneath the house. Then remembered I put it in the shed. Will get to it this week.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostSo went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery connections. Got dark so will mess with it tomorrow. Tried both keys so maybe not VATS. Thinking BCM . Will double check grounds and what not, Not hearing anything from the starter, It’s about a year old. Any other suggestions?
The starter rebuilder thinks it’s an electrical issue, bad ground or bad connection. A lot happens with a starter almost instantaneously. The first is the bendix drive moves out and engages the flywheel (solenoid)
and a millisecond later the power of the starter motor kicks in to spin that bendix gear.
It all needs to happen seamlessly, if a voltage issue happens it throws the whole sequence of events out of whack and bad things happen
That was roughly the explanation I got.. I’ll let you know, been to busy to get back at it. Good luck
Thanks for the info Kubes, checked the starter wire this morning, it was fine. Going to jump the starter tomorrow see if it cranks. I’ll know soon enough, hopefully it is just the starter. I read a bad BCM can cause the problem too.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Checked the starter it cranked over, scared the crap out of me.lol I knew it was going to be quick when I touched both connections together. Going to disable VATS on Hptuners and flash the car.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Disabled VATS it was on PWM changed it to serial. Still no start. Any suggestions, getting ready to call the mobile mechanic for some help. Going to look at the starter relay and the alarm system next.Last edited by ssms5411; 1 week ago.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Anyone know where the starter relay is ? Can’t find one, nothing in the Haynes manual either. Found the fuel pump relay on driver side kick panel. I’m stumped, mobile mechanic is coming tomorrow so I can hope he figures it out, see if he can find my oil leak too.Last edited by ssms5411; 1 week ago.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Check your email.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Thanks Robert, gives me something to look at tomorrow when looking at the car.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
After looking around the internet, I’m pretty sure it’s the ignition switch on the steering column. I’ll see what the mechanic thinks. It’s still stock so over 28 years, I would think it might go out. Ordered the part from Rockauto , not too bad to replace.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Just for info, I got a new key made tried it this morning and does the same thing. I really think it’s the ignition switch on the steering column. Get the part on Wednesday so I’m going to go ahead and pull the old one out.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Finally got the switch yesterday, but now I’m sick with a bug or flu so will be another couple of days before I install it.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Today started to lower the steering column, not a lot of room to get to the switch, don’t really want to pull the steering column but might have to. I replaced the original column off a 2002 SS Camaro in 2010. Has anyone replaced the ignition switch without pulling the whole column out. Will try again tomorrow and if I can’t get it out will call the mobile mechanic to help.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...1 week ago
I stopped driving...2 weeks ago -
Well, I finally am getting some time to get back into these cars. Today I installed a set of no name eBay stainless headers that I’ve had for probably...3 weeks ago
