2001 3800 s2 firebird
Yeah I couldn’t find one either, only for 95-97 , but I think the 98-02 are a shorter bolt, you should be able to reuse your balancer their all metal not like my 1996 which is rubber on the inside which dry rots and goes bad.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by thatpewterfirebird View Postneed help finding a balancer and a replacement balancer bolt. i'm at a lost after confusing myself researching.
I installed the 97+ on my 96 years ago.
95-96 on left - 97+ on right
Raven
- 1 like
Nice Robert, I forgot that it’s 1997 to 2002 that are the same. This is a sticky on the top of the threads also.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
So I replaced my crank sensor and ****ed up my original one pulling it off wrong. The one I got off a Camaro at the scrap yard is wobbling bad. I have the one on the right and I just reused my bolt. So get the one on the left? And what about a bolt?
Originally posted by FirebirdGT View Post
Why do you need to replace the balancer? 95-96 is p/n 12563267 - replaced with p/n 12563281 for 1997-2002, which does use a shorter bolt and is discontinued.
No you still use the one on the right. The bolts are TTY so you need a new bolt.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Looking around on the internet , you might be able to use a Grand Prix series 3 balancer and bolt, not the super charged one, the N/A one. It’s the one with the rubber on the inside and uses the longer bolt. Just from what I’ve read might be an option since I couldn’t find a new bolt. And if that’s the case then a Camaro 95-96 balancer and bolt could be used. Might need a case relearn on the computer. Maybe FirebirdGT will chime in and see if that is a option.Last edited by ssms5411; 4 hours ago.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.3 days ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...5 days ago
