Tranny Mounts - FirebirdV6.com/CamaroV6.com Message Board
Tranny Mounts
  • Tranny Mounts
    I'm getting a really loud clunking noise when i drop the clutch above like 3k RPM. I know my tranny mounts are stretched and worn because when i bought the car, none of the motor mounts were attached and the oil pan was sitting on the frame, supporting the engine.
    Is this noise possibly the tranny twisting and knocking back down? If not i'll probably get new tranny mounts anyways. Any suggestions on which to buy and how much to spend?
    -Kevin<br /><a href=\"http://heinz.no-ip.com/Car%20Pics/IM000117.JPG\" target=\"_blank\"><b>\'96 White Camaro RS M5</b></a> <br />GTP Shortblock - T3/T4 -6psi Intercooled<br />Open Downpipe
    ...anyone?
      bump
        Try www.gmpartsdirect.com if your going stock. If you don't mind a little bit of noise :D try a poly mount. Those you can get at about any autoparts store for a fraction of the price of a stock, but you will have to make the bolt hole longer on the crossmember brace.
        95 Camaro 3.8L Y2K motor <br /><a href=\"http://www.cardomain.com/id/coriya71\" target=\"_blank\">www.cardomain.com/id/coriya71</a>
          yea whats a good after market tranny mount.. becuase when i fix up my trans i want to get shift kit and vette servo in it and i remember my friend blew his Tranny mount twice when he had shift kit in his car
          99\' W68 Firebird<br />SLP Ram air kit,Whisper Air Lid, k&n, 8mm Taylor Wires, Bridgestone Potenzas RE950, BMR Red LCAs, Pacesetter Headers and 3\"in catalytic converter with 2.75\" Flowmaster Cat-back<br /><br /> <a href=\"http://www.cardomain.com/memberpage/501008\" target=\"_blank\">http://www.cardomain.com/memberpage/501008</a>
            What do you mean by a little noise?
              i have an Energy Suspension urethane tranny mount on my car. basically, when you first install it, it has to break in. this takes about two weeks to a month depending on how you drive it.
              the mount will be real loud the the ride will seem a lot more 'primitive'. once it breaks in, the noise goes away.
                Yea I have a prothane tranny mount. Annoying the first couple weeks then the noise goes away and it loosens up a bit. One of my favorite mods (I went threw about 3 stock mounts lol)
                00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
