i went to autozone to get my SES light code pulled, they said that my plug under my steering wheel isnt hooked up, is there anything i can do on my own to fix it, or has anyone else had this problem??? [img]graemlins/toto.gif[/img]
OBDII, mine doesnt work????
Try somewhere else? They might have been connecting with the wrong gateway? I dunno ... check fuses ... darn thing should be hooked up.
Make sure you're a 95 (or 96?) or newer, as those have OBD-II. OBD-I has a similar plug, but no II interface.
-Rob<b>97 Camaro 3.8L M5</b><br />Car for sale<a href=\"http://terpmotors.com\" target=\"_blank\">terpmotors.com</a> Terrapin Motorsports! UMCP
For OBD-I, short the correct pins, and the SES light will flash 20-whatever times, displaying the code for you. If you can't do that, go to Autozone and buy the $20 OBD-I reader (II's are 10x that), which does it for you, and can probably reset.
whatever dealership said that is wrong, it is obd1 for 6's & 8's of those years...2001 75th Anniversary V6 Pewter Firebird w/ Chrome Wheels, T-Tops, & Y87<br />Mods: Free Ram Air, !Silencer, Holley Filter, Full 3\" Hooker Catback, 3\" Cat<br />Best time: 15.095 at 90.00 MPH with a 2.127 60\'
Ask them to pull your codes as an OBD-I computer. If they can't or refuse, grab a paperclip, or buy the OBD-I code reader / clearer for like $20 (?), and you'll have it for yourself. But I really thought you just shorted (connect w/ paperclip) two pins, and the light would flash the code.
Supposedly, you can short pin A & B(?) and codes will flash. It sure didn't work for me. I had to take it to a mechanic to pull and clear codes. That $20 code puller from Autozone is an expensive paperclip. ;)\'94 Camaro 3.4<br />\"No, Starvin Marvin. That\'s my pot pie.\"
<blockquote>quote:</font><hr>Originally posted by Wicked 3800 V6:
-Rob<hr></blockquote>
The $20 code readers will only work on cars that came from certain factories from what I understand. I have one and it won't work on my 94 or my friends 95.
Lets make this real simple. If your ALDL connector is a RECTANGLE shape, it's an OBD1 style connector and the paperclip trick WILL WORK.
If your ALDL connector is a TRAPEZOID shape, it's an OBD2 style connector (regardless of weather it's an OBD1 or OBD2 ECM)and the paperclip trick WILL NOT WORK.
[ April 11, 2002: Message edited by: Dan90RS ]</p>Dan<br />1990 RS 170,000 miles<br />3.4L collecting dust<br />700R4-to-T5 swap completed on Dec. 13, 2002
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...1 week ago
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...3 weeks ago
by ssms5411So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...4 weeks ago
