i went to autozone to get my SES light code pulled, they said that my plug under my steering wheel isnt hooked up, is there anything i can do on my own to fix it, or has anyone else had this problem??? [img]graemlins/toto.gif[/img]
OBDII, mine doesnt work????
Try somewhere else? They might have been connecting with the wrong gateway? I dunno ... check fuses ... darn thing should be hooked up.
Make sure you're a 95 (or 96?) or newer, as those have OBD-II. OBD-I has a similar plug, but no II interface.
-Rob<b>97 Camaro 3.8L M5</b><br />Car for sale<a href=\"http://terpmotors.com\" target=\"_blank\">terpmotors.com</a> Terrapin Motorsports! UMCP
For OBD-I, short the correct pins, and the SES light will flash 20-whatever times, displaying the code for you. If you can't do that, go to Autozone and buy the $20 OBD-I reader (II's are 10x that), which does it for you, and can probably reset.
whatever dealership said that is wrong, it is obd1 for 6's & 8's of those years...2001 75th Anniversary V6 Pewter Firebird w/ Chrome Wheels, T-Tops, & Y87<br />Mods: Free Ram Air, !Silencer, Holley Filter, Full 3\" Hooker Catback, 3\" Cat<br />Best time: 15.095 at 90.00 MPH with a 2.127 60\'
Ask them to pull your codes as an OBD-I computer. If they can't or refuse, grab a paperclip, or buy the OBD-I code reader / clearer for like $20 (?), and you'll have it for yourself. But I really thought you just shorted (connect w/ paperclip) two pins, and the light would flash the code.
Supposedly, you can short pin A & B(?) and codes will flash. It sure didn't work for me. I had to take it to a mechanic to pull and clear codes. That $20 code puller from Autozone is an expensive paperclip. ;)\'94 Camaro 3.4<br />\"No, Starvin Marvin. That\'s my pot pie.\"
<blockquote>quote:</font><hr>Originally posted by Wicked 3800 V6:
-Rob<hr></blockquote>
The $20 code readers will only work on cars that came from certain factories from what I understand. I have one and it won't work on my 94 or my friends 95.
Lets make this real simple. If your ALDL connector is a RECTANGLE shape, it's an OBD1 style connector and the paperclip trick WILL WORK.
If your ALDL connector is a TRAPEZOID shape, it's an OBD2 style connector (regardless of weather it's an OBD1 or OBD2 ECM)and the paperclip trick WILL NOT WORK.
[ April 11, 2002: Message edited by: Dan90RS ]</p>Dan<br />1990 RS 170,000 miles<br />3.4L collecting dust<br />700R4-to-T5 swap completed on Dec. 13, 2002
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...5 hours ago
