When i roll my window half dowd, a little below half way or a little above halfway my window begins ratteling, and recently there are new scratchesand scuff marks on my window towards the back side of the window, and idea what this maybe and two anyone know of how to get rid of these scuffs?
Driver side window problems
1995 Firebird (3.4) <br />Eagle 18\" 077<br />Flowmaster 80 (2.75\") series exhaust<br />2.5\" Car Sound Cat<br />K&N Cold Air Intake <br />Alpine 12\" Type E Sub<br />Bazooka EL 1500 Amp<br />Pinoeer deh4400 and Aftermarket Speakers<br /> <a href=\"http://www.sounddomain.com/id/fbird\" target=\"_blank\">http://www.sounddomain.com/id/fbird</a>Tags: None
I had the same problem. The reason your window is scratched is that the broken metal is rubbing your window. The problem piece is a window guide thats attached to the top rear of the door. There are 2 in on each door and their job is to keep the window from rattling back and forth. It is a cheap part and available at your dealer. You will have to remove the interior door panel to replace it.1999 Camaro Hugger Orange 3800 A4 <p>Mods-SLP SS exhaust, K&N, SLP STB, SLP SFCS, 1LE Sway Bars(32/19), 99 C5 Wheels on 255/45ZR17\'s-17\'s on all corners...Non-Y87
$8.14
I just did this a few days ago.
Roll the window down. Remove the plastic piece around your door handle and lock slider, then the door panel (just like 5 screws), pull it off, and on the top of the door there will be two metal things bolted on with one 10mm bolt each (i think its 10mm). Each should have a felt thing against the glass.
Go to the dealership and ask for a window guide/stop and then bolt it on.
Adam<a href=\"http://members.cardomain.com/adamon6thstreet\" target=\"_blank\">1996 Firechicken</a><br /><b>15.19@91.61</b><br /><i>It Rocks Your Panties</i><p>Daily Driver: <a href=\"http://members.cardomain.com/pimpnon6thstreet\" target=\"_blank\">1990 Pontiac Trans Sport SE</a><br />Most recent mod: Mounted an Evan on the dashboard.
