fan switch mod? - FirebirdV6.com/CamaroV6.com Message Board
fan switch mod?
  • fan switch mod?
    one of the fan switch mods needs a 300 ohm resistor i cant fide one, will 270 or 330 work or should i wire two together to make 300 ohm
    please help
    1998 green camaro, bear rotors.<br />It\'s not how much money you have, It\'s how many toys you have.
    o believe i used 470 if i am not mistaken....my friend did all the wiring i just watched
    Haha i am better then u all ..not whats up all?
      I've read both 470 ohm and 47 ohm so I am not really sure I have some 47 ohm resistors at the house but I just decided I would deal with the SES instead of soldering them!
        I just did mine last week...you need 470 ohm 1/2W resistor, 5% tolerance
        Eric
        Eric
        2005 Mustang 4.0
        1996 Camaro Conv
        2000 Ford Excursion
        "Darkness Falls"
          2 days ago
        • Doodler
          97 Camaro base with expensive sounding noises
          by Doodler
          Still trying to find oil leak
