I'm guessing the switch is going bad? Whenever my headlights are up/on and I go to turn them off, the lightd go out but the headlight stays up?? I hear the motor trying to bring it down, but it just stays up.
Is there anything I can check(bad connection)under the hood or in the car? Both headlights are staying up.
Thanks for any help
94 3.4L A4 white t-tops<br />moroso cai<br />3\"hi-flow pacestter exhaust<br />b&m shift kit<br />catco cat<br />01 T/A rear w/ 3.73\'s and posi<br />1 pc aluminum ds<br />blacked out signals
Your sig is the most important part of your message. Make sure that you list EVERY single thing that you have done to your car so that we can all go \'oooh!\' and \'Ah!\'. Please make your sig consistently longer than anything else you post. Please include your lengthy sig with EVERY single post you make during a reply, even if you only reply with a monosyllable grunt.
