Head light switch/motor - FirebirdV6.com/CamaroV6.com Message Board
  • Head light switch/motor
    I'm guessing the switch is going bad? Whenever my headlights are up/on and I go to turn them off, the lightd go out but the headlight stays up?? I hear the motor trying to bring it down, but it just stays up.
    Is there anything I can check(bad connection)under the hood or in the car? Both headlights are staying up.
    Thanks for any help
    94 3.4L A4 white t-tops<br />moroso cai<br />3\"hi-flow pacestter exhaust<br />b&m shift kit<br />catco cat<br />01 T/A rear w/ 3.73\'s and posi<br />1 pc aluminum ds<br />blacked out signals
    I find it difficult to believe that not a single member on this board ever had this problem ?
    Is there a search for this? I could not find one, so please if there is let me know where...thanks
      What exactly did you search for?
      try searching for "headlight motor"
      or click here
      Your sig is the most important part of your message. Make sure that you list EVERY single thing that you have done to your car so that we can all go \'oooh!\' and \'Ah!\'. Please make your sig consistently longer than anything else you post. Please include your lengthy sig with EVERY single post you make during a reply, even if you only reply with a monosyllable grunt.
        here's the free headlight fix linky
        here is the one with the brass gears you can purchase.
        ---Niño---<br /><i>95\' silver 5 spd</i>
          Good Deal. Thanks pontiac, that is exactly what I was looking for
          • 187shark
            by 187shark
