AC causing engine to cycle - FirebirdV6.com/CamaroV6.com Message Board
  • AC causing engine to cycle
    when im in park and turn the AC on the engine will start cycling like it will go from 1000 RPM to 1500 RPM constantly does anybody know what the problem is and how to help, me this is really startin to piss me off.
    Weird.
      Isn't that normal? I know my idle bumps up a little when I crank on the AC...
        I'd suggest popping the hood and seeing if the compressor is cycling on and off .. like every few seconds it comes on then shuts off.. if that's what's happening then you likely have low freon.. the compressor will do this in order to keep from burning up if you are low on freon..
        -Brad
        2000 V-Star Custom 1100
        :rock:
          hey thx man thats what it was i was just low on freon thx for the help
            being low on refridgerant will not cause the motor to rev to 1500. and the a/c compressor is SUPPOSED to cycle on and off, which will cause the engine rpm to change slightly. If you are too low on refridgerant, the compressor will completely stop after you drive and will just blow hot air.
            1995 Firebird 3.4L<br /><a href=\"http://kansas.no-ip.com/\" target=\"_blank\">My Site</a>
