NEED HELP - FirebirdV6.com/CamaroV6.com Message Board
NEED HELP
  • NEED HELP
    How do u take the inside door panel off on a 99 firebird cannot figure it out!! Need help ASAP!!! like the hard vinyl part because mine is cracked!!
    !!No Worries!!<br /><br /> <a href=\"http://www.cardomain.com/memberpage/515424\" target=\"_blank\">http://www.cardomain.com/memberpage/515424</a>
    Whassup 99firebird99?
    I have never tackled the whole panel, but I searched the site and came up with this thread.
    It may be of some help...if not holler back!
    Blessings!
    www.camarov6.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=1;t=006217
    if this doesn't come back as a link....cut and paste it to an explorer screen.
    \"this isn\'t flying...its falling...with style!\"<br /> -Buzz Lightyear<br /><br /><br /> 96 bright red firebird, T-tops, monsoon CD Flowmaster catback dual exhaust <br /><br /> <a href=\"http://members.cardomain.com/joyfellowship1\" target=\"_blank\">http://members.cardomain.com/joyfellowship1</a> <br /> <a href=\"http://www.joyfellowshipchurch.com\" target=\"_blank\">www.joyfellowshipchurch.com</a>
      Thanks that helps a lot!
        What do i do now???
        Door
        I got two big screws out and one small one what next????
        1 Big one was in the holder on the door
        1 Big one was in the door under the electrical stuff
        1 Small one was holding the locking mechanism on!!
          IF it is anyting like my 96 camaro after you get all of the screws out you lift straight up and the panel will come loose from the upper part of the door and the lower locks (be careful of those) it should just come right off if you got all of the screws out.
          Remember that sometimes, silence is the best answer.<br />Warren White<br />1996 PoloGreen Coup <a href=\"http://vampyr.settanni.net/\" target=\"_blank\">http://vampyr.settanni.net/</a> <br />\"Jealousy\"<br /> CTFBA member of the month Sept 03
          • Andy H
            Transmission removal help!!
            by Andy H
          • 2.8 Bird
            Abs inop
            by 2.8 Bird
          • fishin
            by fishin
