I just had to get my rear main seal and crankcase fel-pro gasket fixed/replaced. The bolts also appeared to be loose so they tightened them as well. At first everything seemed fine, but then I started to notice more and more that when I'm driving around 29-32 mph and go WOT the trans won't shift into overdrive like it used to prior to the repair. What does everybody think? Suggestions, comments, concerns, etc? What could it be and how can I fix it? Also my car seems to be a little sluggish of sorts. Not all the times but only some of them. I tried resetting the PCM, twice. I even checked and cleaned the air filter to make sure that wasn't the problem which results in a lack of pep/power. I can still dust the little ricers that are around the area [img]graemlins/burnout.gif[/img] , but I just don't like not having that overdrive downshift at that speed like I used to have. Let me know what everybody thinks. Any help is appreciated. Thanks in advanced.
-Chris
-Chris
