well they tell me its more than that, they say the torque converter is going and all this other crap. so i dunno i dont even want to bother with it these trannys suck
F-body common repairs, problems
99\' W68 Firebird<br />SLP Ram air kit,Whisper Air Lid, k&n, 8mm Taylor Wires, Bridgestone Potenzas RE950, BMR Red LCAs, Pacesetter Headers and 3\"in catalytic converter with 2.75\" Flowmaster Cat-back<br /><br /> <a href=\"http://www.cardomain.com/memberpage/501008\" target=\"_blank\">http://www.cardomain.com/memberpage/501008</a>
Yeah, that can happen. They said my fluid was burnt from the torque converter slipping. But they said the torque converter was still ok because there was no friction material in the pan. You may have waited too long with the TCC valve failing and fried your converter. You have to catch it early. Still, all you should need is the Sonnax TCC kit and torque converter which should be about 700 bucks altogether. If you can get a good tranny for about the same it's probably worth it.1999 Y87 Camaro<br />Whisper Lid, SLP SS Takeoff Exhaust
I'm gonna have to be an *** and be the guy to tell you otherwise. I am approaching 116k and I am on stock EVERYTHINFG still. Meaning alternator, radiator, shocks, struts, starter, water pump etc. I have had problems with my ignition and I replaced my rear axle, but nothing that was surprising to me. I am still amazed at this little ****er of an engine is still pulling like the day I got it with 45k97 Camaro RS<br /><br />\"Just a V6 huh?, let\'s go find out how slow it is\"
Alternator,radiator,battery,Crankshaft position sensor,MAF sensor,tensioner assembly,VSS sensor(leak),Both window motors,PCM,new key,power steering hose,plug wires,tranny mount,rear main seal
[ December 14, 2004, 11:00 PM: Message edited by: Coriya71 ]95 Camaro 3.8L Y2K motor <br /><a href=\"http://www.cardomain.com/id/coriya71\" target=\"_blank\">www.cardomain.com/id/coriya71</a>
2 alternators
plugs and wires (about a month ago)
Catalytic converter
flush cooling system1999 Camaro Silver 5spd<br />Appearence Mods:<br />-Clear Corners -Tail Lights off a 93-96 Camaro -Painted Black Calipers w/ Silver Camaro Decal on front ones -Black Camaro Rear Fill Decal -Silver Camaro Front Fill Decal -Painted Silver Interior Pieces -RKSport Shift Knob<br />Performance Mods:<br />-Eibach springs -Whisper Lid -Removed MAF screen -Free Ram Air -Trans Am Dual Exhaust -3\" Cutout<br />Stereo System:<br />-Eclipse 8v Head Unit -Eclipse 87series 12\' Subs -Rockford Fosgate 800wt amp (subs) -MTX 225wt amp (highs)<p>AOL IM is jay eub, msn messenger is banks_2003@hotmail.com
KNocks on wood...103k on mine
New wires at 95k (only because the #3 wire burned)
new plugs at 85k (replaced because I felt like it) with AC Delco Professionals (NGK TR55ix's in AC Delco clothing), noticed zero gains in MPG or power which said to me that the stockers really do last to 100k no problem
2 fuel filters because I drive a lot
I think the previous owner replaced the belt, I put 30k on the car since I bought it, still looks fine.
Change tranny fluid and filter every 10-12k with walmart brand fluid, runs great
The dreaded valve body replacement due to the P1870 code and replaced TC at the same time because I felt like it with a stall converter.
Oh, my passenger side valve cover started leaking about 5k ago, so I replaced the gasket. Also decided to polish the valve covers when I replaced the gaskets, now I have two bling bling valve covers. :D
And thats it. Original alternator, A/C compressor, water pump, radiator (AND fluid, I know how to add water to it, I love dexcool),p/s pump and tensioner.
I'm pretty sure the rear axle gear oil has never been changed either. I think I have one of those exceptionally reliable f-bodies. However, my thirdgen has power everything. I knew better. I told the guy at carmax, I want THE MOST STRIP DOWN F-body you have on this lot. I really didn't want an A4, but they didn't have any M5's in my price range.-1999 Camaro Coupe 3800 Series II V6 A4 - SOLD<br />-1998 Pontiac Grand Prix GTP coupe
water pump
power steering pump
PCM
fuel filter
alternator
radio (twice-both stock)
plugs
wires
2 ignition coils
PCV valve
2 window motors
other regular wear and tear stuff
95,800 miles<a href=\"http://bellsouthpwp.net/d/e/defrag/sig.jpg\" target=\"_blank\">1997 Firebird V6-Y87/W68</a>
window motors, ignition cylinder, rear main, and rear pinion are common
i've replaced:
starter
oil pump
coils
headlight motors (nothing you need to worry about)
on the way out:
window motors
passenger window and lock switches
rear speakers (that's my fault haha)
67k1996 Pontiac <a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">Firebird</a> <br />Black, 3.8L A4
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...4 weeks ago
