Please help - FirebirdV6.com/CamaroV6.com Message Board
Please help
  • Please help
    i just replaced my coil pack well at least one of them i screwed up the fireing order now i know the order i just dont under stand witch side is what and how to plug them all back in
    the problem in the first place was it ran really ruff and the check engine light would flash once i got up to a certain speed what would really help would be a diagram or something please help i need to drive this car to work tommarow and i screwed it all up thanks
    uhh...
    green 97 camaro<br />cowl hood<br />chrome z28 5 * rims<br />grille tech front grill<br />rk sport spoiler<br />flowmasters & 3\" tips<br />K&N intake<br />600 watt fosgate w/ 2 fosgate 12\'s<br />limo tint
      If you are talking about the spark wire then you will have to play with them untill you get them back in the right place. If you know someone that has a car like yous just look at how they go on their car and do the same to yours. Hope this will help for that matter I hope this is what you are talking about.
      • Bluebird92
        1992 Firebird
        V6 5sp
        Go to a parts store and get a manual for your car. If you work on your car it is a must. In there you will find everything you need. you can also do a search for "firing order" and see what you get.
        White 98 Camaro with t-tops leather and Y87. For more info on mods just ask.<br />1/4=14.9<br />2002 Xterra V6 A4
          THANKS GUYS BUT I GOT IT LAST YEAR I DID A TUNE UP AND REPLACED ALL OF EVERYTHING TODAY I REPLACED 2 COIL PACKS AND THE MODULE AND STILL THER SAME THING ANY IDEAS WHAT IT COULD BE IT IS MISSING THE ONLY OTHER THING I COULD THINK OF IS BAD WIRES BUT I BOUGHT GOOD ONES AND I FIND IT HARD TO BELEAVE DAMN IM GOIN CRAZY WITH THIS
          • Andy H
            Transmission removal help!!
            by Andy H
          • 2.8 Bird
            Abs inop
            by 2.8 Bird
          • fishin
            by fishin
