Limp mode - FirebirdV6.com/CamaroV6.com Message Board
Limp mode
  • Limp mode
    Do our PCM's have limp mode? I'd say so for when it sets a serious code, like the misfire codes that make the SES light blink.
    I've been told that ANY code will set the PCM to go into limp mode. Well my SES light has been on for about 2 months now, and I've ran my best time with that thing on it. Its for the stupid P0420 code (catalyst system low efficiency) because I have a leak at my converter.
    Is this true for the OLD OBD 1 ECMS? Anyone know more info on this? If my PCM is in limp mode, I CAN'T WAIT to see how it runs when its in normal mode.
    -1999 Camaro Coupe 3800 Series II V6 A4 - SOLD<br />-1998 Pontiac Grand Prix GTP coupe
    I'm going to assume that's what the reduced engine power light is for. IIRC, in the manual, it says when that light comes on, the PCM reduces the power of the engine, along with other things because of a serious (?) problem, and that you need to take the car to a mechanic immediately to get it checked out
    Oh yeah, almost forgot, I read this in my 2000 camaro owner's guide
    2000 silver A4 Camaro<br />Whisper lid; Free Ram Air; BMR stb; MSD super conductor wires; Gatorback belt?<br />1986 RX-7 (daily driver)
      Now I wonder if thats true for the LT1's or not...
        Yes, it does have a limp mode. The "Reduced Engine Power" light will come on.
        Has to be a serious problem for it to come on though. Your P0420 won't put it in "limp mode".
        SLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)
          The car will go into limp mode, and it will retard the timing significantly and I don't think it lets you rev over 3500 rpms...
          Mine went off once, I seafoame, let it stall, pulled the MAF off the car then cleaned the TB and started the car with the MAF off, got it to crank since it was flooded to hell, it started but was very sputtery then popped into limp mode, I stopped it reinstalled maf, then fired it up, drove it a little, shut it down restarted and all was good.
            Thank you, these answered my questions.
              6 days ago
