Why is it that,,, - FirebirdV6.com/CamaroV6.com Message Board
Why is it that,,,
  • Why is it that,,,
    ...Cars with smaller engines are making more ponies than us stock for stock in some situations?
    For example, the Pontiac G6 on a stock 3500 V6 motor is putting out 240 HP but on a stock 3800 V6 Motor we're only capable of putting out 200 HP?
    Engine, 3.5L 3500 V6 SFI (200 HP [149 kW] @ 5600 rpm, 220 lb-ft [298.0 N-m] @ 3200 rpm)
    Matt
    1998 Mystic Teal Camaro M5
      I say technology and just what's in. Back during the 3rd generation look and see how much the 8's were putting out. Heck in high school, the 5.0 mustangs were one of the fastest things on the road. Now our cars can beat them without any problems. But because of the import craze a few years back, once again it's in vogue to have high HP engine. Just look at how high v-8 power is on newer engines. The 3.8l Series II is basically like a 15 yr old design.
      95 Camaro 3.8L Y2K motor <br /><a href=\"http://www.cardomain.com/id/coriya71\" target=\"_blank\">www.cardomain.com/id/coriya71</a>
        Yup, engine technology is getting better. 25 years ago big-block V8's were making 200-some HP because of emissions restrictions. It took awhile for manufacturers to learn how to make computer controlled engines that get better gas mileage, produce less emissions yet still increase power. VVT, multi-valve, multi-displacement, etc.
        Many 6 cyl cars are now making in the 250-275 horsepower range and the LS2 is up to 400 hp, something that GM hasn't achieved since the ZR1.
          They are raising compression ratios quite a bit on a lot of cars nowadays to get more performance out of em...I wonder what our car would put out if the cr was upped to 10:1 or higher?
            any thing above 10 you need lots of tunning and stuff...... our heads are only like 64cc i think
            and even at 10 your going to need like 93 fuel
            also high C/R helps lower emisions cause it burns more of the mix becuase of the hotter temps in the chamber
            www.turbov6camaro.com
            1997 3800 Series II Camaro
