Alternator Problems - FirebirdV6.com/CamaroV6.com Message Board
Alternator Problems
  • Alternator Problems
    This may be a little long.
    Started the car yesterday.. Voltmeter stayed in the red. Revved the car up and started to drive after about 5 minutes.. The meter popped up to normal. Started it later that night it did the same thing. This morning I started it is in the red, but not extremely low. I disconnected the ground cable to the battery and the car died. My question is, is it normal for the alternator to start and stop. Or is the electrical system in my car screwed up some way.. Either way, I have to use my lunchbreak to get a new alternator.
    :mad:
    2000 Camaro Z/28
    have your dealer pay for the new alternator (under drivetrain warranty if you still have one).
    if the dealer wants to argue about it (and you still have the warranty), argue with them. They will give in.
    I just bought my car 3 weeks ago and I called about getting the alternator replaced (phone), but they said they didn't think it was covered. If i end up having to replace it, they are going to replace it free of charge under my warranty [img]graemlins/evilgrin.gif[/img]
      His car is a 94, Im not sure if GM warrenty's are that long. My alternator did act a little funny off and on before it went out. Best thing you could do is just have autozone or a local parts store do a test on the battery and alternator.
        Eh.. hate to be the one to tell you. But the 3.4 has the tendencey to eat alts. I'm on the 4th one now. But one every 2 years could be worst.... could be one a year!!
        BTW. Here in Detroit. You'll pay 130.00 for one.
        Steve
        FirebirdV6.com/CamaroV6.com Administrator
        Stupid is rewarded with the ban button.
        Official Avatar Nazi according to Meatyshells :D
          Alright,
          I went on my lunchbreak, get in the car and the damn thing acts like there's nothing wrong. I disconnected the ground wire and the car continued to run.. Can the belt or any of the pulleys be causing this problem? I'm gonna see what it does when I get off work and decide from there. Does the sqeaking that I get in the morning have anything to do with this also.. This will he the second alternator that I've had to replace on this thing.. the price for a new one is $116
          Thanks for any info..
          2000 Camaro Z/28
            replace the belt ,your problem may go away. the squeeking could be a loose or worn belt causing the alt to not function right.
            99 Dodge Quadcab<br />Traded: 2001 Camaro(will be missed)<p>Be wary of anything that can bleed for 5 days and live....
              I agree, replace the belt first especially since it is the cheapest option. See if it helps if not then have your alternator and battery checked as well as your electrical/ignition system. Its a definante possibility that the alternator is the problem. I have had to replace my alternator twice within 2 years. But try the belt first.
              [ July 16, 2002: Message edited by: Skullcamaro ]</p>
              1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
                6 days ago
