1.If you don't have a supercharger or nitrous, is the use of buying piller guages any good besides an appearance mod?
2.I like the look of them but I wouldn't buy them unless they're functional to my car in some type of way. if i go for a piller setup, what would i hook it up to (water pump,air/fuel?)considering i don't have too many mods at the moment but i plan on building up.
My ride: <br /><a href=\"http://members.cardomain.com/youngdeezy\" target=\"_blank\">http://members.cardomain.com/youngdeezy</a><br />98 Firebird 3.8L A4<br />Mods:80 seires flow master muffler<br />dual exhaust 3\" pipes,whisper lid<br />k&N filter,3.42 gears and LSD, 180 thermostat, free ram air mod & 1/2\" raised air box + some apperance mods<br />1/4 mile 15.8 @ 85mph<p>I\'ll see you in the traffic...
they are only as functional as you want it to be. you dont need a boost gauge in there just to make it acceptable. i would get a air/fuel ratio and maybe engine temp. gauge. if you wanted you could get a tri pillar and put three clocks in there with different time zones in each. it is all up to what you want.
