I found water in my rear well yesterday. This is the first time that this has happened. I would assume that the rear hatch is leaking.
Could this be caused by the weatherstriping being bad? How do you check this? And if the striping is bad, where is the cheapest place to buy a replacement set and how much does this cost?
i would guess that its the weather stripping. cant help with were to find them though. if its were your tire is, it might be coming through the intenna hole, or through a crack where your lights r
There is a gm bulletin on leaking rear hatches...It shows the fix too...See if a local dealer would be cool enough to print it out for ya...If not let me know and i'll get it and fax it to ya or something.
