Headlight Help Please - FirebirdV6.com/CamaroV6.com Message Board
  • Headlight Help Please
    Ight, i've searched for awhile now and havnt founda nything that really helps. I need to know why my Headlights pop up when i select juz the parking lamps, and how do i stop this from happening. Its REALLLY ANNOYING. Is is juz my bord or do others do it, thanks for the help in advance.
    1995 Firebird<br />CAI<br />Painted Interior White<br />De-badged Doors<br />MTX System<br />16x8 Epic Marquis Rims<br />--Next Mod to Come--<br />lowering kit, tint
    Mine also does this, but only sometimes. If i have the headlights up and then close them to turn on just the parking lights then they'll come up. Mabey its a 95 thing?
    I just found this at bfranker's site:
    "On a side note, something else that often happens when this nylon gear strips is your headlights doors will pop up when you turn on just your parking lights. Or, your headlight doors will quickly go up then down when you arm the alarm. I can't exactly explain WHY they do this when the gear is stripped (headlight control module gets out of whack maybe?) but they often do. And, believe it or not, when you fix the ratcheting noise (either rotate the gear or buy one of my metal ones) it will almost all the time fix the headlight doors coming up when they shouldn't! Don't ask me how or why, but it often does [img]smile.gif[/img] "
    [ July 16, 2002: Message edited by: AcidDrag0n ]</p>
    <a href=\"http://www.xbox3604free.com/default.aspx?r=381546\" target=\"_blank\">http://www.xbox3604free.com/default.aspx?r=381546</a>
      Moving to Gen. Tech
      Good luck with a fix [img]smile.gif[/img]
      <b>« Red <i><a href=\"http://sandman.v8tec.com\" target=\"_blank\">Firebird</a></i> »</b>
