I've got a problem that came slowly on my car (99 V6) : when the car is cold, after accelerating, each time I release the throttle, engine RPM goes down to 1200 RPM, holds it 4-5 seconds then goes back to 700-800 RPM
If I don't accelerate at all after start, the car will heat slowly and RPM will never go over 800 RPM.
Before that, my idle was always 700-800 RPM even when engine was cold. It happens only in winter, and it doesn't make it when engine is hot.
I've checked my PCV valve and it's like new.
Seems there's no IAC valve because I have electronic throttle. SES light off. No leaks from air filter to throttle body.
When car is outside for several hours and it's cold, I've noticed a weird sound under the hood, like air being sucked or metal shaft spinning without oil (whistle). Could that be a leak from the intake manifold?
My car has 20 000 miles on the clock, Dynomax super turbo and free ram air mod.
Any help appreciated,
Thanks,
Fred
Thanks,
Fred
