car is not idling right, ive replace every thing, plugs, plug wires, air and fuel filter, injectors, coil packs,pcv valve. Its a 3.8, 1999 model, it idles at about 625 rpm, does that sound right. When i plug my scanner into it, the only thing that shows up is evaporative system monitor, i do not have any check or service engine lights on. Could that be it, and where is it located, i traced all my vacuum lines under the hood and they all look good. Some ones got to help me, with all the problems ive been having im fixing to sell it, any one interested?
not idling right
not idling right
<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.Tags: None
If it's saying Evap Emmisions Monitor, check the hose that's coming from the passenger side of the engine. It's plastic and looks like this http://pics.xs.to/pics/04082/P1010018.JPG
and here is the link I got it from http://www.camarov6.com/ubb/ultimate...c;f=1;t=013539
That hose is plastic, breaks very easily, and it threw many of Evap Emmision codes at me. I replaced the plastic hose with a regular rubber vacuum hose. It works much better!sigpic
