throttle body screw - FirebirdV6.com/CamaroV6.com Message Board
throttle body screw
  • throttle body screw
    Whats the correct setting for this screw one the front drives side of the throttle body, such as if i screw it all the way in, how many full turns out should it be set at. I took off the throttle body and cleaned it the other day, turned screw half a turn and it pooped out. so i jest put it back in.
    [ September 01, 2004, 10:20 PM: Message edited by: BobbyZ72 ]
    oh its a 1999 3.8
      When I installed my tb spacer, it came with longer studs to accomodate the spacer, but the principle of it should be the same. I just tightened them all the way down using the "double nut" method.
      2000 3.8L Firebird, Silver Metallic<br /><br />\"Yes, London. You know, fish, chips, cup o\' tea, bad food, worse weather, Mary f***in\' Poppins, London!!\"
        What "screw" are you talking about?
        Matt
        1998 Mystic Teal Camaro M5
          No, the ONE screw im talking about is the one on lower-front-drivers side of the throttle body. i think 99 is diffrent then the 98, my throttle body is "drive by wire"
            your probably talking about the throttle blade adjustment screw....i'd say just turn it out until the motor will idle like it used to, just tune it by ear...
            <b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
              thats the way its set right now.....thanks
                Ahhh, I see...I thought he was talking about one of the studs that holds the tb on...haha
