So, the 94 Z is runnin rough and missing, but not throwing a code. Initially i thought pass. side plug wires or injector. What are some other causes of this that wouldn't throw a code??? Would the plug wire throw a code? HHEEELLLLPP!!!!
maybe you guys can help... LT1 question
~Jessica~<br />Office Manager @ <a href=\"http://www.fbodycentral.com\" target=\"_blank\">http://www.fbodycentral.com</a> <br />2001 Firebird GT NBM, A4<br /> <a href=\"http://fbodyqueen.tripod.com/\" target=\"_blank\">http://fbodyqueen.tripod.com/<Tags: None
When I burned through a plug wire (it literally came apart in the repair guy's hand), it didn't throw a code initially. Later on, the problem got worse, and it started throwing codes then. I don't remember which codes, because I was still bone stock at the time, and took it to a shop to get it scanned.\'99 Silver Camaro M5 T-Tops<br /><a href=\"http://www.cardomain.com/id/papismark\" target=\"_blank\">http://www.cardomain.com/id/papismark</a><br /><br />Intake and exhuast so far. More to come...
sounds like the same diagnosis... i'm definitely thinking it's the pass. side wire, because we had a little mishap.. with a fire on that side.
thanks! anymore input is helpful~Jessica~<br />Office Manager @ <a href=\"http://www.fbodycentral.com\" target=\"_blank\">http://www.fbodycentral.com</a> <br />2001 Firebird GT NBM, A4<br /> <a href=\"http://fbodyqueen.tripod.com/\" target=\"_blank\">http://fbodyqueen.tripod.com/<
can I have some history on the car and maybe what mods were done? could be a ton of things but knowing when the last tune up was done would be a great help1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...13 hours ago
