Are there any special tools that i need to change the fuel filter on my car? I don't exactly want it blowing up in my face or losing too much gas. thanks...
1996 Red Camaro 3.8L<br />Details, you say? Go here.<br /><a href=\"http://www.angelfire.com/trek/brl866s/camaro.html\" target=\"_blank\">Slick Red</a><p>\"A Great Warrior defeats his enemies by smashing their fists with his face.\" - A Great Warrior
No, no special tools needed. You just need a wrench (I forget what size) and a LOT of rags. The one end of the filter is kinda like an air hose fitting, you pull a metal sleeve back and it pops off. The other end requires 2 wrenches> one to hold the filter still, and the other to turn the nut. Have some rags handy and try not to have your face directly below the filter while performing this or you'll know what 87 Octane tasts like...like I did.
Oh, this may qualify as a "DUH", but DON'T SMOKE!!!!!
Marc.
Will i need to jack the car up on some jackstands or can i just get to it on the ground? Also, can i catch any leaky gas into a CLEAN bucket? and put it back in the tank?
you dont need tons of rags just one...just run your car till its basically out of gas. then get the wrench and change it. yes some is going to come out but just get a pan to let it run into
2001 SOM Camaro SS<p>Direct flo lid---Lakewood LCAs----Edelbrock Torque Arm-----Lous Short Stick---Dynomouth 3\" Exhaust---SLP Center Mount Exhaust---Poly tranny and torque arm mounts.<p>My site....http://community.webshots.com/album/49413018hRfdbP
Try taking off your gas cap and then releasing pressure at the shcreder valve on the fuel rail.(make sure you tuck some rags under the valve. When you take off the filter at least it won't spray on you but you will get some that drips out.
95 Camaro 3.8L Y2K motor <br /><a href=\"http://www.cardomain.com/id/coriya71\" target=\"_blank\">www.cardomain.com/id/coriya71</a>
Is there a way to keep the fuel leakage to a minumum?
You can pull the fuse for the fuel pump & start the car for a few seconds until it starts to stall, then shut it off. Supposedly this will get the fuel out of the lines. Whenever I used to do one, I just took the gas cap off whatever car I was working on & went to work. BTW, you'll beed a crescent wrench & a 5/8 open-end wrench for the job. Just make sure before you start the car you put the fuse for the fuel pump back in, & then turn the key to the ON position (don't start the car) to prime the fuel system. Do this once or twice, then you can start the car.
2001 Onyx Black Camaro M5-Totalled<br />2005 Ford F150 XLT 5.4L<br /><br />\"To make peace, prepare for war.\"
<blockquote>quote:</font><hr>Originally posted by Fin: You can pull the fuse for the fuel pump & start the car for a few seconds until it starts to stall, then shut it off. <hr></blockquote>
Never though of that, Thats a good idea. I might replace mine soon and I'll try this technique. Thanx!
Marc
