Basic Tune Up Questions - FirebirdV6.com/CamaroV6.com Message Board
  • Basic Tune Up Questions
    My car has 210K miles on it, and if it isnt in this list, then I haven't changed it.
    Fuel Pump, fuel filter regularly, cat, plugs, wires, clutch, driveshaft, tranny fluid, radiator fluid, oil every 2K & filter, rotors & pads, new MAF, new idle control valve. Is there anything else I should/should have changed or any suggestions? My mpg isnt all that great anymore, and it seems to idle rough. Some Seafoam and injector cleaner is all I can think of. Thanks for the help. [img]smile.gif[/img]
    -down
    \'96 Black Camaro M5<br />17x9.5\" O.Z. Monte Carlos, Eibach sportlines, SLP-CAI, Edelbrock cat-back
    O2's
    PCV vavle
    clean the TB
    book says the wheel bearings are suppose to be done at 100K miles
    i wouldn't worry about the sea foam i would get the hole top of the motor cleaned by a pro.
    i would bleed your brake lines and put new fluid in there if you haven't
    bleed your clutch till it's all new fluid if you never did it.
    check all suspention for wear and make sure there is grease in the grease fittings.
    check all vaccum line lines for dryrot and cracks.
    check all coolent hoses for crack's
    REPLACE YOUR WATER PUMP should have been done 2 time's already !!!!
    www.turbov6camaro.com
    1997 3800 Series II Camaro
      i would like to [img]graemlins/bowdown.gif[/img] at how many miles you have on that car with it still running decent.
      what about you rear end fluid? its getting pretty old.
      you never said your coolant. change it if you havent [img]tongue.gif[/img]
      [ December 27, 2004, 03:04 AM: Message edited by: BLLDOGG ]
      2000 3.8 A4 Pewter Camaro
        umm tranny and coolent and Power steering and any fluid in the car lol should be given fresh all fresh fluid
          A top engine clean will improve gas mileage, make your car idle so much better and bring back horsepower. With that many miles im sure theres quite a bit of carbon built up.
          Vipers got all the things that would want to be checked and done up above [img]smile.gif[/img]
          1999 Pontiac Trans Am M6 Far from stock.....
            wow I hope my car still runs at 200K its at 152K at the moment and still running strong. Just goes to show you if you take car of your car it will run forever.
              Well, everything mentioned has already been changed. And if you really really take care of the car, it'll last a Very long time. My stock clutch lasted 170k miles, and the car runs absolutley fine. Water pump lasted till 150k miles, so I have a fresh one. Where is the PCV valve and how much? Should i do anything about the EGR? I've cleaned the TB. Rear end is fine, wheel bearings as well. Any and all fluids have already been changed. Any more suggestions are appreciated!
              -Down
