I have an oil leak its not that bad but it is leaking on my Ypipe and on the oil pan. IS this comen or what if so how much to fix thaz
Hi iem from Fbody.com sad to say i need some help
Whisper lid PPI amp JL 12\" Bosten 6 1/2 Clear coners <br />K&N And hyper white all around 3.73 auburn posi 180* <br />Mangna Flow TransGo shift kit, Jet chip stage 2 <br />Altezzas (carban fiber) <a href=\"http://members.fbody.com/jdyson209/\" target=\"_blank\">http://members.fbody.com/jdyson209/</a>Tags: None
What year car? Can you tell where the leak is from? How big of a leak is it?
Just to throw the simplest idea out there: Make sure your drain plug is tight enough and the rubber washer is in good shape. If it is from the oil pan itself then it may be the oil pan seal... Not a huge deal to fix, just a pain to fix ( ive never done it on a newer car, only on my old 65 Mustang I used to have ).
~Brian
[ May 20, 2002: Message edited by: DeathBuzzz ]</p>NEW 2002 Onyx Black SS Camaro<br />M6, leather, T-tops, Hurst shifter<p>sold: 1999 Pewter V6 A4 Camaro
its a 98Whisper lid PPI amp JL 12\" Bosten 6 1/2 Clear coners <br />K&N And hyper white all around 3.73 auburn posi 180* <br />Mangna Flow TransGo shift kit, Jet chip stage 2 <br />Altezzas (carban fiber) <a href=\"http://members.fbody.com/jdyson209/\" target=\"_blank\">http://members.fbody.com/jdyson209/</a>
Could be your rear engine seal(think thats the proper name for it?), mine leaks on my y-pipe all the time and the oil pan, and down my tranny, etc. It's fixable but a PITA.95 Camaro 3.8L Y2K motor <br /><a href=\"http://www.cardomain.com/id/coriya71\" target=\"_blank\">www.cardomain.com/id/coriya71</a>
If you look at it under the car, clean everything off with some brakeclean or carb clean, then run it for a little while and get back under there to see exactly where its coming from. Its really hard to tell because it blows all around under there. If its the pan, you MIGHT be able to chaneg the gasket without lifting the engine, if its the rear main, you have to drop the tranny. I have the same problem, but its not bad enough for me to mess with it yet. Just smells once and a while.1997 Chevrolet Camaro v6 - 13.8@104MPH
1997 Dodge Viper GTS
What type of oil are u running?2002 M5 Bright Metallic Silver <br />*Fully loaded and modded<br /><br />2005 GSXR 750<br />*Micron Serpent Race Exhaust *K&N Filter *Power Commander *Trying to hit 200 MPH!<br /><br />1970 SS 454 Chevelle Cortez Silver<br />*It can pass anything but a gas station
Its most deffinately your rear main seal. Im sorry to say that this is seldom a fixable problem. I used to have a Jeep Cherokee that this happened to. I got it fixed twice and still leaked.
But, at least take it to a mechanic and let him look at it!
[img]graemlins/love.gif[/img]
*Knight*<a href=\"http://members.cardomain.com/adamon6thstreet\" target=\"_blank\">1996 Firechicken</a><br /><b>15.19@91.61</b><br /><i>It Rocks Your Panties</i><p>Daily Driver: <a href=\"http://members.cardomain.com/pimpnon6thstreet\" target=\"_blank\">1990 Pontiac Trans Sport SE</a><br />Most recent mod: Mounted an Evan on the dashboard.
i had to drop the tranny to replace the rear main seal in my 94...have fun. but i wouldn't wait around to have this fixed because the oil will get in your clutch and it will start slipping.<a href=\"http://members.aol.com/gus2816/images/sig.jpg\" target=\"_blank\">R.I.P. 3.4</a><br /><i>97 SS 30th anniversary white with hugger stripes</i>
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...2 hours ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....4 days ago
