what size hole should i drill in the fire wall to run my 3 gauges through? Also wheres the best place to put the hole?
Question about gauge install
Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....Tags: None
um, why would you drill a hole when there are already two holes for wiresits never really a good idea to go drilling until you have the two holes stuffed with wires. if you want to know where they are at, one is on the driver side and the othe is on the passanger side behind the PCM. thats the one i always use
Ok one hole , the passenger side, would be ok to run the wires and vacuum line. Problem is the wires have to run to my gauge pod which is on the Drivers side. Problem being the wires/line won't be long enough. The wires coming out of the drivers side is a connector not an actual hole. Could I possible you the hole the throttle cables run through?Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
i would leave that hole alone with the throttle cable. just cut the wires and extend them. theres a vacumm line huh? is that no too long enough to go through the passanger side? if so, i would keep asking cause i dont know a proper place to drill
Yep your right, the vacuum line is for my boost gauge and is only like six feet longBen<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
ok i got it figured out...i'd extended the wires and i have to make a trip up to summit to buy some more tubing. Thanks for the help.Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
