My engine turned off....... - FirebirdV6.com/CamaroV6.com Message Board
  • My engine turned off.......
    Here's the scoop:
    I had just gotten out of watching Star Wars on Saturday and was bored of my a$$. I went out to some little farm road and took my bird to the limits to see.. mainly just curious. Well when I hit about 118 or so the car shut off on me because the power steering was gone and the oil pressure was at zero and my check gauges light was on. So. I guess this is normal right?? The car works fine I just thought the car would stall out at 118 or so.. Fill me in? I know I'm not the only one that has ever done this. [img]graemlins/toto.gif[/img]
    <b>Red 1999 Firebird M5</b><br />Whisper Lid,Borla Catback,K&N,Dual Friction Center Force Clutch,Hurst Shifter w/Lou\'s Short Stick,!FRA,Suncoast Ramair hood,160 Thermo,!maf,Chrome ZO6 Wheels, Painted Calipers, CIA Headers, Taylor Wires, NGK Spark Plugs, 3\" Catco, Jet Chip Stage II, BMR STB, LCA, PHR, SFC, Fan Switch, FTRA<br /><b>Old Dyno Numbers: 183 RWHP, 217 RWTRQ</b><br /><a href=\"http://community.webshots.com/user/redsixer\" target=\"_blank\">http://community.webshots.com/user/redsixer</a>
    This isn't normal. I had my 2000 do that one time but I was racing with my airbox off and the engine lost air because of the vacuum put on it.
      There is a top speed fuel cut-off at 118mph.
      It won't let you go faster.
        118 is max you can go, but the engine shouldnt shut off and give you all those weird errors like power steering going, and oil and stuff... the car just doesnt pass 118...
        maybe bought a speed limit remover, and it's installed in a wrong way?
          nah some factory installs of the speed limiter are like this -- my car, when you hit 108 mph (speed limit for 1994 3.4L Camaro Manual) the whole engine shuts off.
          -R
          hybrid - \'\'hI-br&d - The offspring of a cross between species.
          Co-Founder West Coast F-Bodies
          West Coast F-Bodies Car Club - WCFB Message Board
            Isnt that kinda dangerous the car shuting down at 118
            ~chris~ 98 Cayenne red Camaro 3800 A4, 3:08, T tops Borla cat-back, wisper lid K&N, Bilstine shocks, Dunlops all around. <br />AOL IM: chevyboyz24
              Isnt it kinda dangerous doing 118 !?!?
              AIS 2 OHH the memories... Great times and putting names with faces.<p>From \"interesting\" hooters waitress(Did you guys FLY ? ) to pissing BMW owners off on the ride home. To ending up in Philidelphia and USING (hahaha) an ice machine. I had a BLAST.<p>Thanxs to all that showed up!!
                I little bit more dangerous to do 118 w/o power steering I think. At least if you had a stick I suppose you could just start back up while you'e going, huh?
                [img]graemlins/burnout.gif[/img]
                  Just to clear one thing up. The top speed limiter for the 3.4L is 118. I know for a fact. I used to have the speed limiter removed before my car was hit in a mall parking lot and I had to have my PCM reprogrammed. The speed limiter for the 3.4L is 118. I verified it this past weekend on the interstate and I had previously checked it with a friend who clocked me going 118 at least for the automatic that is.
                  Your car shouldn't die like that their is something wrong if it does that. I would definantly have it checked out soon before anything serious/costly happens.
                  [ May 23, 2002: Message edited by: Skullcamaro ]</p>
                  1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
                    <blockquote>quote:</font><hr>Originally posted by whtefbrd96:
                    Isnt it kinda dangerous doing 118 !?!? <hr></blockquote>
                    lol said perfectly
                    2001 SOM Camaro SS<p>Direct flo lid---Lakewood LCAs----Edelbrock Torque Arm-----Lous Short Stick---Dynomouth 3\" Exhaust---SLP Center Mount Exhaust---Poly tranny and torque arm mounts.<p>My site....http://community.webshots.com/album/49413018hRfdbP
                      <blockquote>quote:</font><hr>Originally posted by Skullcamaro:
                      Just to clear one thing up. The top speed limiter for the 3.4L is 118. I know for a fact.<hr></blockquote>
                      k man -- whatever you say, and when i was on I-40 and hit 108 mph three times my engine DIDNT shut off and the lights on the dashboard DIDNT all come on. sure thing.
                      just remember not all cars are the same. the manual 3.4L (5 speed) is limited at 108 mph, the Auto 3.4L varies from 115-120 mph (the limiter) - so dont tell me all 3.4's hit 118 and shut off. mine doesn't, which means that not all of them do huh? just remember that.
                      anyway...
                      I hate generalizing statements (if they arent true).
                        Why don't you try reading the whole post before you open your mouth. I say "118 at least for the automatic that is". Try reading it next time and not be a sarcastic a**. "k man"
                          i have a 94 3.4 m5 and it's limited at 118 also.....and it doesn't shut off at the limit, just shuts the fuel off
                          <a href=\"http://members.aol.com/gus2816/images/sig.jpg\" target=\"_blank\">R.I.P. 3.4</a><br /><i>97 SS 30th anniversary white with hugger stripes</i>
                            I also have a 94 M5, and mine also shuts off at 118.
