ELECTRICAL HELP PLEASE - FirebirdV6.com/CamaroV6.com Message Board
  • ELECTRICAL HELP PLEASE
    gotta major issue here
    hit a bump in the road- noticed right side turn signal remained solid when i tried to use it.
    later that night tried to start car it wouldnt turn over.
    tried to jump start it.. still wont start
    conneceted another battery.. still wont start
    it wont even turn over or make clicking noise.
    the kicker is that radio will come on low/highbeams are fine .. left turn signal works
    but it still wont start.
    dont know if it is a fuse or maybe my starter is gone.
    taking it to the dealer.. wanna know what should i ask him to check
    any help would be appreciated
    im guessing your starter is gone.
    2000 3.8 A4 Pewter Camaro
      Have you checked your right turn signal bulbs?
      If when you put the right turn signal on the light stays solid i would guess a bulb is out.
      Based on the information you provided... could it even be possible that when you hit that bump somehow the bulb might have broken and shorted something out?
      Check your bulbs, check your fuses.
      [ September 06, 2004, 11:56 AM: Message edited by: CamaroKRAZED ]
      2000 Monterey Maroon Chevrolet Camaro<br />3.8L V-6/4spd Auto
        yeh when you signal stay solid that means you have a bulb out,
        and the starter sound like no power to the starter or you need hold new one.
        check all fuses even the ones under the hood and then check the wires to the starter (diver side of motor.)
        www.turbov6camaro.com
        1997 3800 Series II Camaro
          When you try to start the car, look at your voltage gauge on your dash. If it drops in power a little when you try to start the car, then it is the starter that is your problem. Most likely the starter solenoid, you could try to jump it. I usually rebuild mine myself. Im not sure if our cars' starter solenoids are rebuildable, but I reabuilt my 3rd gen firebirds about 6 times. :D Anyways, if that gauge doesnt drop when you put the key in the "start" position, then it is the ignition switch or the nuetral safety switch. Good luck. ;)
