Will a jet chip give me better launch?? - FirebirdV6.com/CamaroV6.com Message Board
  • Will a jet chip give me better launch??
    I priced out gears at a local shop here and he told me im looking at 1100 bucks so i guess ill have to wait for gears. But will a Jet Chip Stage 2 give me a little more launch??
    99 Firebird Vert, Pewter Metalic<br />Fast Toys Ram Air<br />Jet Stage 2 Chip<br />17x8 Mille Miglia Emotion II Plus\'<br />wrapped in 245/35/17 Yokohama A520<br />Rhino Perf. Exhaust<br />K&N air filter<br />check pics at:<br /><a href=\"http://www.fastrides.com/members/v6birdy/\" target=\"_blank\">http://www.fastrides.com/members/v6birdy/</a>
    nope
    2000 NBM M6 Camaro Z28<br />323/335
      1100 for gears?!? keep looking dude, find a small mom and pop shop that does good work... stay away from performance shops.. they tend to overcharge...
      99 3800 NBM Camaro - (Xcessive Xcelleration Racing Team)<br />Ram/Cold Air Induction (custom)<br />Modified 4l60e Valve Body<br />Z28 Catback<br />SS Hood <br />Modified 99 GM 3800II <br />JB Performance Engineering<br />jfbperformance@cox.net
        Yeah, labor on gears should be from 200 to 300 bucks. Nope, jet chip doesn't help your launch, but you can feel it at moderate to heavy throttle. Quicker, firmer shifting. Top end is dang good and very noticeable with the chip, and that's where we're lacking. Make sure that you have the supporting mods or don't do it. It's a mod that you may not feel all of the time, especially when weather is real hot. Your engine will run hotter with the chip. Makes up some difference on the high end when racing LT1s.
        I like it, it helps, but don't expect a miracle. It's a bolt-on.
        <b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
