Key Fob programming instructions: - FirebirdV6.com/CamaroV6.com Message Board
  • Key Fob programming instructions:
    Bought a new remote for my car, and the instructions on how to re-program the remote says:
    1- Pull the radio fuse out
    2- Put the key in the ignition, sit inside of the car with the doors closed and turn the ignition on/off three times without starting the car.
    3- The third time turning the key, leave it in the ON position in the ignition (without starting), and you will hear the interior beep confirming.
    4- Then hold the Unlock and Lock buttons on the remote for approximately 10-15 seconds. You'll hear the locks engage confirming the new program.
    5- Replace the Radio fuse, and your done.
    The radio fuse needs to come out so that there is no power to keep memory in the ignition (you know how our car's have the 10 minute delay once the key is turned off?). There is NO memory loss in the radio station programming, it just disengages the 10 minute ignition delay.
    -Marc
