stock 3.4 powerband - FirebirdV6.com/CamaroV6.com Message Board
stock 3.4 powerband
  • stock 3.4 powerband
    whats the powerband of a stock 3.4?
    1985 S-10 w/ 3.4 engine, edelbrock intake manifold w/ 4barrel 500 cfm carb, k&n air cleaner, single glass pack Y\'s into 2-2 foot 3.5\" \"boom tubes\"...very loud
    Not much after 4500 to 5000RPM
    [ April 26, 2003: Message edited by: lando_pr ]</p>
    \'94 Firebird \"El Pichon\" 3.4L A4<br />Mods: CAI,NO CAT,NO EGR,<br />NO PCV,TB BYPASS,SLP IAT module,<br />Dynomax Super Turbo Muffler 2.5\" Dual,low temp stat, fan swtich<br /><a href=\"http://www.geocities.com/lando_pr\" target=\"_blank\">35 years of Firebird</a>
      moving to general tech.
        I would say anywhere from about 20-35 mph.Well thats my powerband on mine. Not sure about yours. Since you are talking about a stock 3.4.
          &lt;chuckles&gt;
          the answer to your question is about 2000-4500.
          its not much of one cause the engine wasnt made for performance (gm just wasnt thinkin bout that when they made the 60* 3.4L back in 1993-95)
          hybrid - \'\'hI-br&d - The offspring of a cross between species.
          Co-Founder West Coast F-Bodies
          West Coast F-Bodies Car Club - WCFB Message Board
            the 3.4 itself has been arong long before that, de stroke/bore it and you've got a 2.8L from the '80s
              i use to have the 2.8 in my pickup...ya it sucked, i blew it up doing a burnout [img]smile.gif[/img] [img]graemlins/burnout.gif[/img] ....really broke my heart too :rolleyes:
                yea its between like 2500 and 5000 my car made peak HP at4700 rpms.... and stayed around there till 4900....
                New:04 GMC Sierra 1500 RCLB 4x4 5.3 GU80 3.73\'s.<br />Truck pics<br />Mods<br />Go fast: Panel K&N filter and soon SS truck catback.<br />Appearance: Stull Billet grill,Weston Chrome step tubes,Rhino Chrome hitch step,ARE painted fiberglass cover,Silver star lighting.
                  <blockquote>quote:</font><hr>Originally posted by pigglyroot:
                  the 3.4 itself has been arong long before that, de stroke/bore it and you've got a 2.8L from the '80s<hr></blockquote>
                  i know. do you know that the 3.4 isnt just a bored/stroked 2.8L? they actually had to make the block slighty larger to accomidate the larger bore (you cant safely bore a 2.8 from 3.508" to 3.623" (its just not doable..cyl walls become weak - and yes i know about the aftermarket kits, those are sonic tested and all that, but they are playing with fire)
                  anyway... so the 3.4 was actually "designed" in a sense. and they had an opportunity to fix some inherent problems with the 2.8 such as lack of power, but they didnt, the block was strengthened, and the intake redesigned (it was an improvement from the crappy 2.8/3.1 intake) but that was about it. the 3.4 cam is the same as the 3.1 cam, just a different degree (the 3.1 is 107 ic, the 3.4 is 111.5 ic)
                  the heads on the 3.1/3.4 are identical, and while the fiero in 89 was using aluminum heads, the camaro in 94 was using cast iron (stupid). so..um...they didnt "design" it for performance, just reused what they had. its gm's attempt at economy for the camaro. not power..you want power? get a v8 (gm's saying in 93-95).
                  anyway. back to the thread...
                  -R
                    with a catback on I say, up to about 4500-4700 RPMs, with it the exhasut really opened up its up to about 2900-5100ish it feels like.
                      2 days ago
                    • Doodler
                      97 Camaro base with expensive sounding noises
                      by Doodler
                      Still trying to find oil leak
