My dash is going haywire!!!!! - FirebirdV6.com/CamaroV6.com Message Board
  • My dash is going haywire!!!!!
    okay, random warning lights have been turning on and off (e.g. airbag lights, seatbelt lights, SES lights) on my car for the last 2 days. At first i thought my ABS was really inoperational. but when i shut my car off for a few hours, and came back, it was fine, but then my car thought my seatbelt was unbuckled when it wasnt. this is getting very annoying, especially since i was just about to put my car up for sale. (i want to get a 3.8L) this happen to anyone? what do i do? [img]graemlins/crybaby.gif[/img]
    -christopher h<p>parting out v6 camaro. <p><a href=\"http://www.camarov6.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=8&t=004216\" target=\"_blank\">http://www.camarov6.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=8&t=004216</a>
    sounds like a short of some kind. Have you spilled a drink anywhere in the past few days? Has it been raining there or had it been?
    White 98 Camaro with t-tops leather and Y87. For more info on mods just ask.<br />1/4=14.9<br />2002 Xterra V6 A4
      spilt a drink... ...where would i look to fix this? i spilt it right over the shift knob (its an auto)....would i just take the center console apart?
        Yeah just take it off and clean it up. If you spilt just water the problem should just go away after a couple days at most but if you spilt something like soda it gets all sticky and takes a long time for it to dry up. I would take off the center console, disconect the battery, and use a rag and windex or water to clean ever wire and connector that you see. Wipe dry as much as you can then let it air dry for an hour or two with the windows rolled down then put it all back together. If you have any trouble taking things apart just let us know ;)
          I dont know if your car has them.. but look out for the airbag sensor.. you will know it when you see it.. be REAL REAL carefull if cleaning up around that area..
          ~Billy
            Mine did something like that when the alternator was going out, is your speedo gauge sweeping back and forth?
            AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
              no, ill try taking it apart and cleaning everything up thoo, and hopefully the airbag won't blow up in my face.
