when should i get a tune-up? - FirebirdV6.com/CamaroV6.com Message Board
  • when should i get a tune-up?
    my camaro has about 54k on it and i was wonderin if i should get a tune-up, and where, i figured i shouldnt go to like ziebart since i have mods, does that make sense? and would the dealer shop do a good job?
    later,<br />alan<br />1999 bright red v6<br />3800 series III<br />208\\210 comp cam<br />3000 stall edge tc
    "Tune-up" used to mean points, condenser, rotor, cap, wires, plugs, timing, PCV valve, yadda yadda yadda.
    Now days with computerized engines, there are no points, no condenser, no rotor, no cap, no adjustable timing, etc. If you get a tune up, you're basically getting plugs and wires. MAYBE they'll clean the EGR and replace the PCV valve.
    If you can do these things yourself, save the money.
    -Brian
    Maroon 1995 Camaro<br />No mods yet...<br />Lucky to have found this site!
      Plugs & wires you can do yourself. Changing the PCV is probably a good idea if it hasn't been done. Also, how long since you had the fuel filter changed?
      2001 Onyx Black Camaro M5-Totalled<br />2005 Ford F150 XLT 5.4L<br /><br />\"To make peace, prepare for war.\"
        i just put on new plug wires, but i dont think ive changed the fuel filter.
          Man I had a code and I told them it was egr valve soleniod 2&3 well they of corse hooked it up to the machine to check the codes so I ended up paying 200 for my egr to be cleaned.
          1995 Camaro 3.4 v6. Dead<br />1995 Trans Am FIPK.
