Air Conditioning Warms Up At Acceleration - FirebirdV6.com/CamaroV6.com Message Board
  • Air Conditioning Warms Up At Acceleration
    Quick Question for you guys. Is it normal for the A/C to get really warm under hard acceleration? Or should I change my Coolant mixture? I'm not even sure what it is right now. In about 800 miles I'm changing the oil as well as the fuel filter so might as well do this.
    What type of coolant should I use? And what mixture should I use for North Carolina summer weather.
    Nope thats normal, our compressors self disable under hard acceleration for more power! :D
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      Sounds good... hey where can I get that a/c wrap locally? I can't find it [img]smile.gif[/img] I want colder air [img]smile.gif[/img]
        JVT, I notice you have a 160 thermo. Technically both fans dont' come on to 210degrees I think. So if your thermo is making the temp stay below that the fans won't cool it off. A manual fan switch helps this a lot. If the temp is bothering you, you can just keep both fans on so it will help cool before it gets up there. It's really helping me a lot.
        Ted
          Actually its not in there yet... i should really take that off. I was going to start and install it one weekend with the manual fan switch (the do it yourself one not the slp one) but I heard it wasn't going to work and give me an SES light.
            It's not for more power.
            It's so the compressor doesn't destroy itself/burn itself out under hard acceleration.
            It is a belt driven compressor...
            R
              <blockquote>quote:</font><hr>Originally posted by Ted:
              Ted
              <hr></blockquote>
              Actually both fans always turn on, its just that they switch speeds. When you turn on your A/C, the fans will always come on low speed when your doing under 40 MPH. Above 40 MPH and with a safe engine temp, they turn off. With A/C on, under 40 MPH, and temp above 210 fans kick on high.
              Never heard of a 160 degree thermo setting a SES light in a '97 3.8L. It might run hot in NC with no manual fan switch, and very cool in the winter, but no SES light. I really recommend a manual fan switch, easy to do, helps out a whole lot.
              ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
                <blockquote>quote:</font><hr>Originally posted by JVT007:
                Sounds good... hey where can I get that a/c wrap locally? I can't find it [img]smile.gif[/img] I want colder air [img]smile.gif[/img] <hr></blockquote>
                Do you have any O'Reilley auto parts stores nearby?
