Need Help Diagnosing! - FirebirdV6.com/CamaroV6.com Message Board
  • Need Help Diagnosing!
    ok,
    my car has been really underpowered, when I floor it it kinda jerks, and shudders off the line, and barely accelerates on the FWY...now, to me it made sense it was a fuel problem, wich Russ suggested, and then I took it to the place that rebuilt my engine (Coast Motor Supply) and they say it's a burnt piston (from driving my car too hard :( ) what does it sound like to you guys?
    Car: 1995 Camaro 3.4L V6<br />Mods: K&N FIPK,3 IN. Flowmaster exaust,RKSports headers,ported/polished heads, Eibach lowering springs, RKSports preformance wing, short shifter<p><a href=\"http://www.cardomain.com/id/equis\" target=\"_blank\">http://www.cardomain.com/id/equis</a><p>Don\'t Let Coast Motor Supply Happen To You.<p>Hear The Roar Of The 3.4
    Sounds like what happened when my MAF fouled in my old car but I dont know enough to say it isnt a burt piston...
    99 3.8 Camaro (M5) Y87
      Our cars don't have MAFs.....
      How are your wires/Coils?
      Sounds like a cyl is not firing. If you have no compression in the cylender then it owudl not be firing...have you had a compression check done?
      [ April 29, 2003: Message edited by: CARdiac ]</p>
      Joel<br />God is my copilot, but Satan has his foot on the gas!<br />94 3.4L AutoCamaroRagtop w/MSD ignition,Accelcoilpacks,K&N FIPK,BMR SFC&STB,3\"Catco w/3\"catbackSS muffler,JetStage 2,HomemadePIAAheadlightconversion <a href=\"http://www.geocities.com/cardiac1968\" target=\"_blank\">http://www.geocities.com/cardiac1968</a>
        well, today in class I'm gonna do a compression test maybe...I'll post my recordings up here.
        -Equis-
          ok, didn't have time for compression test I'll do it tomorrow...but....I pretty much know it isn't a burnt piston...after changing the fuel filter it picks up pretty nicely. I think it's my trans dying (it has a lot of probs) a bad clutch, bad spark maybe...noticed before coil packs had a little bit of corrosion/rust...and I have a **** load of exhaust leaks lol...so, I am pretty convinced now my engine is more or less fine
          -Equis-
            It's not a "burnt piston." The problem is in your ignition somewhere. I would start with plugs and wires. This problems comes up with a lot of 3.4's and the problems is fixed with a simple tune up.
              I had that problem before. I thought the engine was going to have a premature death. :( New plugs and wires turned her back into a beast. [img]graemlins/burnout.gif[/img] :D
              1994 Chevrolet Camaro 3.4L A4 (160hp 200tq)<br />2006 Nissan 350Z 3.5L M6 (300hp 260tq)
                is it throwing any codes?
                  no, no codes, but I've had two people now tell me it sounds like a clutch problem, the car only REALLY picks up in first gear
                    I think it's a burnt clutch, my coils do need cleaning though
                    -Equis-
                      Check your ignition before you jump into a clutch repair. IMHO and with my experience with the 3.4, I can almost 100% guarantee that it's either in the coils, plugs or wires and NOT in the clutch.
                        yeah, well Russ is comin over this weekend and we gonna fix some stuff, he said he's gonna bring over his dremel so we can clean the coils. so I dunno...hopefully it's just that cuz I can't afford a clutch right now ;)
                        • Andy H
                          Transmission removal help!!
                          by Andy H
                        • 2.8 Bird
                          Abs inop
                          by 2.8 Bird
                        • fishin
                          by fishin
