can't find a power programer for the 3.4L? - FirebirdV6.com/CamaroV6.com Message Board
  • can't find a power programer for the 3.4L?
    Where can i find a power programer for my 3.4L firebird?
    1995 3.4L Camillion Firebird<p>Mods: flowmaster,Custom 3inch cutout,Moroso Air intake,2000 firebird rear lights(really makes a diff),fog lights,B&M Quick shifter,Custom Automatic short shifter handle,<p>Upcomming Mods:Pulleys,3 inch Cat,Power chip,headers,gears.. WHICH = ALOT OF MONEY....
    You can't
    As far as I've been able to tell, there is no programer for these cars.
    Sorry, I was ticked too.
    -Brian
    Maroon 1995 Camaro<br />No mods yet...<br />Lucky to have found this site!
      lol this is appearance :D [img]tongue.gif[/img]
      05' CTS-V
      00' Camaro - SOLD :(
        then why does my 95 firebird have the plug under the dash?
          The plug is for scanning the codes
          1994 Pontiac Firebird Formula All Black,red 30th anniversary T/A style racing stripes tinted windows, tailight blackouts, Firehawk-style foglamps Flowmaster exhaust, Moroso Cold Air, leather interior, and my favorite, Ttops<p>1994 3.4 cutom red/black painted firebird,<br />k&n filtercharger, dual outlet exhaust, firehawk-style<br />foglamps, 2000 T/A take off wheels<br />(Finally sold the girl)
            <blockquote>quote:</font><hr>Originally posted by FAST BIRD 95:
            then why does my 95 firebird have the plug under the dash?<hr></blockquote>
            STEP ONE: Go buy a Chiltons or a Haynes manual for your car.
            IN THE MEANTIME: The "plug" to which you refer is for diagnostics. When your SES (Service Engine Soon) light comes on, it will place a code in the memory of the computer. The port is for retreiving those codes. The port also passes some information about the efficiency and status of the engines systems when running. Things like O2 readings, gearshift position, brake operation, you name it.
            Just for your info as well, unless you got one of the rare "california" 3800 95's you've got an OBD1 computer. REGARDLESS OF THE CONNECTOR. The connector on the 3400 looks the same as the OBD2 computers, but it is not.
            Regardless of if you have a 3400 or a 3800, there is no programmer out there. (At least not commercially available) If you need some programing done, you'll have to find someone who can program it for you. Take some KY though, the people who can perform this service usually charge upwards of $400.
            -Brian
              you can get a Jet Stage II module which is supposed to do similar stuff as a Hypertech programmer. all i really noticed from mine was firmer shifts though.
              94 Firebird - Red A4<br /> <a href=\"http://members.cardomain.com/predatorbird\" target=\"_blank\">http://members.cardomain.com/predatorbird</a>
                Does anyone ever buy the Stage 1 JET Chip? I was just curious because I was thinking that maybe no one is ready for the stage 2 JET chip and that is why there are so many complaints about it.
                Just a thought. [img]smile.gif[/img]
                  <blockquote>quote:</font><hr>Originally posted by Brian Dieckman:
                  You can't
                  -Brian
                  <hr></blockquote>
                  Actually the 3.4 cars do have them available. They are extremely difficult to find though. You can only buy them used so just be on the look out for them.
                    Hypertech came out w/ programmers for the 3.4's a long time ago but later recalled them b/c they didn't work good. there are some out there like someome said. good luck trying to find one though.
                      ok. so here i go trying to correct a lot of wrong info...:
                      #1. The 1993-1995 3.4L F-body came OBD1 Equipped! However, in 1995, since they were putting OBD2 into the 1995 California 3.5, some of the 1995 f-bodies also got a OBD2 connector, but OBD1 programming. I HAVE A 1994 3.4L CAMARO -- and my connector is an OBD1 - 12 pins, and square and black. the OBD2 connector has 10 i believe, and is shaped like an ATARI plug, and is grey in color
                      #2. The Hypertech Power Programmer DID EXIST! Hypertech made them up until around 1997. Production was stopped because there was not enough demand. Mods back then (i should know i was trying to mod my car) for the 3.4 were scarce (sp) if not non-existent.
                      #3. Yes the plug under the dash is for scanning codes. However, HPP used this plug to interface with the computer, hence the misconception that the port is only for programming.
                      If you find a Hypertech Power Programmer, good luck using it. I talked with a friend of mine that had one. In the instruction manual, it stated that once you used it on a car, it recorded the VIN Number and could not be used on any other car but the one with the VIN Number. Dont ask me how it knew - that is just what I was told. be careful of used ones.
                      IF anyone reading this has a Hypertech power programmer, I implore you -- share it with your friends (if i am wrong about the One car thing) because they are few and far between and near impossible to find.
                      -R
                      hybrid - \'\'hI-br&d - The offspring of a cross between species.
                      Co-Founder West Coast F-Bodies
                      West Coast F-Bodies Car Club - WCFB Message Board
                        Tested gains according to So-Slow V6 are only eight(8)RWHP. Save yout money and get a custom reprogram. ;) :D
                        FRANKLIN H. <br />1995 Silver Camaro L32 <br />K&N,Flowmaster,HPP,160*,1LE,Zexel-Torsen,ES,BFG,Michelin,Bilstein,Eibach,C5 rims,!CAT,!AC
                          <blockquote>quote:</font><hr>Originally posted by Russell:
                          -R
                          <hr></blockquote>
                          So where does the "wrong info" come into place? All the information you gave was the same as what was above.
                          I originaly said there wasn't one available, and there isn't.
                          -Brian
                            well for us 3.4L cars i found and ordered my programer today [img]graemlins/fluffy.gif[/img] ...it was hella hard to find brand new but i got one and it was cheap to..on the web site it said that they where out of stock but i called and they said that they haven't updated it so they do have.. can't wait to see what it does and if it was worth it it..
                              Hey email me and let me know where you got it bongo46@yahoo.com
                              My new ride 2000 camaro, No mods yet still waiting for warranty to run out then all out heads, cam, and supercharger
                                2 days ago
                              • Doodler
                                97 Camaro base with expensive sounding noises
                                by Doodler
                                Still trying to find oil leak
