HELP my car is a POS - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    If injector cleaner doesn't help it my vote is its the fuel pump as well.
    I had the same problem!!!
    • #17
      Thanks dude!
      I had the pressure read they said 44
      hmmmmmm........
      i'll try injector cleaner, how do I use it?
      Soon to be Mommy!<br />2005 Honda Pilot EX-L
      • #18
        I don't think it's the pump. If your FP were going bad, wouldn't the car cut off occasionally while you were driving, not just give you problems starting?
        2002 Firebird <br />Mods: Whisper CAI and Lid, K&N, Edelbrock Cat-Back, Hurst Billet Plus Shifter w/Lou\'s Short Stick, BMR STB, 32mm front sway bar w/polygraphite bushings and end links, PHB polygraphite bushings, HPP3 tuned
        • #19
          no not really most of the time when they run they wont cut out but if there going bad it will not want to start at first
          • #20
            Ah...last car I had a fuel pump die on was an 80 prelude, which was carburated ... about a month before it croaked, sometimes when I engaged the clutch the engine would die ... but, big difference in fuel delivery in the cars, obviously ... just floating that out there.
