I'm planning on doing a manual fan switch tomorrow. i'd like to cool my car down in-between runs at the track. I have a switch in my car already, the previous owner had neons hooked up to them but he removed them before i bought the car. i hooked up strobe lights in the footwells, but i got tired of them since they barely work. i'm gonna remove the strobes, and then run some wire from the switch to the fan wire. would i be better off tapping the low-speed or high speed fans?
Doing a manual fan switch tomorrow
\'98 Camaro - SOLD<br />Best E/T: 15.489 @ 86.48 MPH<br />60\': 2.131<br /><a href=\"http://members.cardomain.com/skorpion317\" target=\"_blank\">members.cardomain.com/skorpion317 </a><br />1998 Saturn SL2<br />Official <a href=\"http://www.njdisturbance.com\" target=\"_blank\">NJ Disturbance</a> bracket racerTags: None
or used a DPDT center off toggle and run both the high and low speed. you can aslo run LED's to show what fans are on.. would look something like the one I made ;)
http://www.mainstreamtopics.com/harlan/Switch2a.jpg
http://www.mainstreamtopics.com/harlan/Switch3a.jpg1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
i already have a switch in my car i can hook it up to, however it is only an on-off switch. it was used for neons in the footwells. I'm probably just gonna tap the high-speed fan wire, since i'll need to cool it down quick in between runs.\'98 Camaro - SOLD<br />Best E/T: 15.489 @ 86.48 MPH<br />60\': 2.131<br /><a href=\"http://members.cardomain.com/skorpion317\" target=\"_blank\">members.cardomain.com/skorpion317 </a><br />1998 Saturn SL2<br />Official <a href=\"http://www.njdisturbance.com\" target=\"_blank\">NJ Disturbance</a> bracket racer
Be careful, the neons probably needed a 12v signal to turn on, and your fans need a ground to turn on if you go to the wires over the front passenger tirewell. Don't put 12v to them, only ground.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
ok so is this how i should do it?
switch----fan wire-----ground\'98 Camaro - SOLD<br />Best E/T: 15.489 @ 86.48 MPH<br />60\': 2.131<br /><a href=\"http://members.cardomain.com/skorpion317\" target=\"_blank\">members.cardomain.com/skorpion317 </a><br />1998 Saturn SL2<br />Official <a href=\"http://www.njdisturbance.com\" target=\"_blank\">NJ Disturbance</a> bracket racer
ground to the switch, then that wire out through the PCm gromet and tie into the high or low speed wire in thee connector. shown here. http://shbox.com/1/fan_switch_wires.jpg
That will work. all teh switch will do is groun that wire which in turn activates the relay1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
ok wait....I have to take a wire, run it to the switch, and then ground it on a bare piece of metal. then i run a wire from that wire and tap into the fan wire?\'98 Camaro - SOLD<br />Best E/T: 15.489 @ 86.48 MPH<br />60\': 2.131<br /><a href=\"http://members.cardomain.com/skorpion317\" target=\"_blank\">members.cardomain.com/skorpion317 </a><br />1998 Saturn SL2<br />Official <a href=\"http://www.njdisturbance.com\" target=\"_blank\">NJ Disturbance</a> bracket racer
tap into the cig lighter ground or any metal ground under teh dash, Run that wire to the switch. then from the other termonal on the switch run that to either the high or low speed wire under the hood1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
tap into the cig lighter ground or any metal ground under teh dash, Run that wire to the switch. then from the other termonal on the switch run that to either the high or low speed wire under the hood\'98 Camaro - SOLD<br />Best E/T: 15.489 @ 86.48 MPH<br />60\': 2.131<br /><a href=\"http://members.cardomain.com/skorpion317\" target=\"_blank\">members.cardomain.com/skorpion317 </a><br />1998 Saturn SL2<br />Official <a href=\"http://www.njdisturbance.com\" target=\"_blank\">NJ Disturbance</a> bracket racer
not always. don;t guess. run it yourself. if you ply power to that fan wire by misatke you run teh risk of burning up the driver in the PCM. not to mention burning up the relays and fuses. Just start from scratch.1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
ok the switch IS grounded, i took the panel off to make sure. i have a wire going through the passenger side firewall hole and running to the switch. i just need to make sure i know where to tap the fan wire. do i tap it BEFORE or AFTER the connector it goes into?\'98 Camaro - SOLD<br />Best E/T: 15.489 @ 86.48 MPH<br />60\': 2.131<br /><a href=\"http://members.cardomain.com/skorpion317\" target=\"_blank\">members.cardomain.com/skorpion317 </a><br />1998 Saturn SL2<br />Official <a href=\"http://www.njdisturbance.com\" target=\"_blank\">NJ Disturbance</a> bracket racer
doesn't matter. anywhere on that wire and your fine [img]smile.gif[/img]1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
