Misfiring - Help with Parts suggestion - FirebirdV6.com/CamaroV6.com Message Board
  • Misfiring - Help with Parts suggestion
    My engine is misfiring - took it to Pep Boys for daignosis and Cylinder 5 is going nuts. So I'm replacing coils, wires, and plugs.
    Any suggestions and the parts I should get? The coil they said to get is E51. I'd like to take a step up from normal plugs and wires and put something good and durable in there - please gimme suggestions/links.
    This'll also be the first time I've done this - doesn't look too bad, but please gimme any suggestions with procedures and tools. So far I've just looked in the Chilton's Repair Manual.
    It's a 2001 3.8L Firebird.
    Also gonna do air filter and get a Whisper Lid while I'm at it - suggest: Holley or K&N?
    - Mike<br /><br />Pewter 2001 Pontiac Firebird<br />Bone stock<br /> <a href=\"http://members.cardomain.com/nighteye\" target=\"_blank\">http://members.cardomain.com/nighteye</a>
    MSD Coils
    Taylor wires
    NGK TR55 plugs
    stick with that combo, and youll be happy.
      Thanks - do any local parts stores like AutoZone carry these, or am I gonna have to get'em off the 'net?
        Originally posted by Ian:
        MSD Coils
        Taylor wires
        NGK TR55 plugs
        err make that MSD wires and you'll be happy longer
        www.turbov6camaro.com
        1997 3800 Series II Camaro
          I found the plugs and wires - but which model MSD cooil do I need?
          I think its this one: http://www.msdignition.com/coil_blaster_9.htm confirm, anyone?
          • Andy H
            Transmission removal help!!
            by Andy H
          • 2.8 Bird
            Abs inop
            by 2.8 Bird
          • fishin
            by fishin
