bolt torque for belt tensioner? - FirebirdV6.com/CamaroV6.com Message Board
  • bolt torque for belt tensioner?
    I had to replace my belt tensioner. It was just one long bolt holding the hole tensioner on. I am wondering, should there be any washers and what is the correct torque for this piece?
    Thanks,
    Chris
    If it didn't come with washers it doesn't need them.
    Put a box-end on it and pull till you can't pull anymore - its tight enough.
    <b>15.41</b> @ 89.80 & 15.45 @ <b>91.64</b>, 2.21 60ft, 3,440 raceweight, using <b>OEM</b> Equipment. <br />\'98 L67/M49 w/ 134,000 miles before spun bearing. \"<i>It\'s all stock, Baby</i>!\"
      2 days ago
    • Doodler
      97 Camaro base with expensive sounding noises
      by Doodler
      Still trying to find oil leak
