Changing Spark Plugs and Wires - FirebirdV6.com/CamaroV6.com Message Board
  • Changing Spark Plugs and Wires
    Is it worth it to have the plugs and wires changed or to do it your self, looks like a pain in the *** but i dont know. How Much would it cost me to have them changed??
    1998 3.8 Red Camaro A4<br />Z28 Flowmaster 80 Series Catback,3:08 gears,K&N Filter,Whisperlid Induction,Raised Airbox,
    ...actually I have the same problem with my wires.
    I tired to change them on the weekend but it was tooooo hot and pain in the butt. So, I gave up.
    When I got my spark plugs changed in the fall I paid $350 CDN. I didn`t change the wires, though.
    As far as I know wires should last you for a long time.
    When you get them changed make sure they`re placed and protected (silicon and coating) properly, that will ensure you they last longer.
    My wires where touching somewhere and the ruber melted and started the misfire. For quick fix I just sprayed it with with silicone and it`s better but I`ll changed them in 2 weeks.
    i hope this helps
    97 Camaro RS
      <blockquote>quote:</font><hr>Originally posted by Stovall98:
      Is it worth it to have the plugs and wires changed or to do it your self, looks like a pain in the *** but i dont know. How Much would it cost me to have them changed??<hr></blockquote>
      It is a pain in the a$$ to do yourself, but that's half the fun of owning a car isn't it.
      I also know most places will charge you quite a bit to change them for you.
      2000 GTP<br />Thrasher CAI, 3.4\" pulley, DHP PCM<br />Member RedLineVSix<br />Best ET-14.02<br />Best Trap-97.15
        When I had my plugs changed at 75k I had my mechanic do it, cost me about 100 bucks for labor and plugs. When it came time for wires I had a friend help me. Took us less than 2 hrs, and that was doing 8 wires (I didn't realize some wires were longer than others, so we had to switch around a few [img]graemlins/dunce.gif[/img] ) I imagine plugs are harder than wires, but if I had it to do over again I'd do it myself, wires were alot easier than I thought. Get a friend who's done a plug change before, some jack stands and ramps, and you'll be good to go. Good luck [img]graemlins/thumbsup.gif[/img]
        <a href=\"http://www.cardomain.com/id/briansr\" target=\"_blank\">97 White Pontiac Firebird 3.8 A4</a><br />Mods- 2.75\" exhaust, Dynomax muffler, magnaflow cat, SLP CAI, Hypertech 160* thermo, Fan switch<br />Suspension-Kumho Ecsta 712\'s, 32mm/19mm sway bars<br /><br />Our Lady of Blessed Acceleration, don\'t fail us now. <br />-Elwood Blues
          I just paid $186 for plug, wires and fuel filter install plus i bought all the parts.
            Changing the plugs and wires was under a hundred bucks for me.
            I just changed 1 plug wire at a time, running the new one in the same location and making sure the convaluted tubing was protecting the wire as designed, rather easy process.
            The sparkplugs were a experience.
            I changed #1 and #2 from the top.
            I put the socket on the plug from the bottom and ratcheted them out from the top on #3 and #4 (especially difficult to get to).
            I changed #5 and #6 from the bottom and thought they were the easiest to do.
            I also suggest verifying the plug gap.
            I have never trusted that 'pre-set from the factory' BS.
            Your plug gap should be .060
            Good luck if you do it yourself!
            :cool:
            <a href=\"http://www.geocities.com/red69falcon/\" target=\"_blank\">1969 Falcon</a><br /><br /><a href=\"http://community.webshots.com/album/81706526iUXWli\" target=\"_blank\">1972 Harley & Misc. Project Pics</a><br /><br /><a href=\"http://www.geoci
              I paid about $110 for the plug/wire install, and I provided the parts. I bought the NGK plugs and Taylor wires for about $75. I attempted it myself, however it was more than I could tackle in the parking lot at my college. The plugs are a huge PITA to reach because of their placement. It's up to you on how much twisting you want to do or to just pay someone.
              AIM: Alientr8tr<br /><a href=\"http://www.cardomain.com/memberpage/583450\" target=\"_blank\">1998 Camaro 3.8L</a><br />Flowmaster 80-series, !FRA, Eibach Springs, KYB AGX, SLP sway bars, 3.42/LSD, Wings West kit, Z06 Motorsports, Silverstone Metallic paint<br /><a href=\"http://www.shift5.com/\" target=\"_blank\">Shift 5</a> - My Band
                Do it yorself!!!!!! This is the easiest way I found to do the plugs on 3.8's. I've already done it twice.
                1, 2, and 4 from the top
                3, 5, and 6 from the bottom.
                1997 Camaro 3800 5-speed<br />Flowmaster 80 series catback dual exhaust w/ chrome tips and !cat mod<br />K&N Drop In w/ Removed silencer<br />Freedom Designs STB<br />Motorola Hands Free Kit<br />Code Alarm Security System<br />Eclipse 5441i and PPI Amplifier<br />Q-logic dual enclosure w/ Polk 12\" subs<br />Reflective Concepts rear fill<br />Rear Front and Fog black outs<br />20% side tint 5% rear tint
                  with the right tools and the know how, its no problem at all...
                  merlin
                  2002 Firebird<br />2003 Yamaha YZF 600R
